Hard to find small part
Old Oct 9, 2011 | 10:31 PM
dmayhew's Avatar
dmayhew
Default Hard to find small part
Does anyone know if the small clamp that is used to hold to the 2 steel vacuume lines that run across the fire wall for wiper door operation is available from any of the parts suppliers?
Not the clamp behind the brake booster, but the one just to the left of the wiper limit switch? There is a screw that protrudes straight up from a horizontal surface on firewall and the clamp is enlongated to hold the 2 steel lines.
David
Old Oct 9, 2011 | 11:29 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
David.. it holds the two lines together? 71 right..
Old Oct 10, 2011 | 08:50 AM
dmayhew's Avatar
dmayhew
Correct sir, 1 line sits in front of the other, so the clamp is enlongated to allow for the 2 to set side by side. One metal line is larger diameter than the other.
David
Old Oct 10, 2011 | 03:41 PM
Alan 71's Avatar
Alan 71
Hello David,
The clip that's used is very similar (or maybe the same) as the clip used for the fuel lines on cars with fuel return lines, and also on the drivers side where the long brake line and vapor line run parallel to each other. The original clip is shaped to hold 2 lines, one bigger than the other.
If you need one I'll send you one.
Regards,
Alan
Old Oct 10, 2011 | 04:19 PM
dmayhew's Avatar
dmayhew
Originally Posted by Alan 71
Hello David,
Regards,
Alan
Thanks Alan,
I would like that very much if you have one you can spare, I will be glad to pay you for the part and postage.
Can you tell me what kind of nut was used on teh screw? Lock Nut or std nut with lock washer?
I will PM you my address
David
Old Oct 10, 2011 | 06:46 PM
0Willcox Corvette
Former Vendor
Originally Posted by dmayhew
Thanks Alan,
David
David.. I'm sure Alan will come through for you.. he always does.. but if something goes wrong email me and I'll dig you one out of the old clip bin I have. I feel sure i have a used one and tomorrow I'll take a look.
Old Oct 10, 2011 | 10:03 PM
dmayhew's Avatar
dmayhew
Thanks Wilcox,
I will be replacing the rear rotors this winter, I will be sure to give you the business.
David
Old Oct 11, 2011 | 11:00 PM
0Willcox Corvette
Former Vendor
you always do David.. and thank you...
To Hard to find small part
