T Top Handle sag
Old Oct 12, 2011 | 12:19 PM
Dantana's Avatar
Dantana
Default T Top Handle sag
Hi All,
Anyone have any advice to fix a T Top handle that constantly falls down as I drive the car? It's the rear handle on the driver's side. It is not releasing the top, just falling down about an inch. Looks busch league...
Thanks,
Dan
Old Oct 12, 2011 | 12:29 PM
MelWff's Avatar
MelWff
Is the adjusting screw tightened correctly?
Old Oct 12, 2011 | 12:34 PM
MrJlr's Avatar
MrJlr
Originally Posted by Dantana
Hi All,
Thanks,
Dan
LOL...EXACT same problem on the EXACT same handle...
Old Oct 12, 2011 | 12:37 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The t-top lock should have between 13-16lbs of load at the back of the handle to release them. A fishing scale is a good cheater tool to use for this if you do not have the correct one.
This tension or "load" is obtained by adjusting the bolt in the front of the latch as Melllf described.
Willcox
Old Oct 13, 2011 | 08:36 AM
Dantana's Avatar
Dantana
simple fix, thanks guys!
i can't believe i've been looking at that handle for 2 years and it took less than 2 minutes to fix...
Forum comes through once again
Old Oct 13, 2011 | 09:31 AM
75+78 Corvettes's Avatar
75+78 Corvettes
I hate that handle on my 75. I've knocked my head on it a few times because it doesn't stay tight and falls down sometimes when I drive it. luckily, the tops are off it most of the time.
Old Oct 13, 2011 | 11:26 AM
7T1vette's Avatar
7T1vette
That is a 'cam lock' lever. Either the adjusting stop/nut [at the opposite end of the lever] needs to be screwed outward to tighten it up or the cam mechanism (pivot) is worn out to where it will not work at all. Try making the adjustment. If that won't work, you need a new lever mechanism...or duct tape.
To T Top Handle sag
