79 Corvette Power Problems
Old Oct 13, 2011 | 01:46 PM
ashes0's Avatar
ashes0
Default 79 Corvette Power Problems
This basically started happening out of nowhere and it randomly starts and stops so I can't put my finger on it.
At random times I'm getting no power, none for lights, horn, and when I turn the key the radio doesn't come on and of course, it wont start.
When it first started doing this, I would push the car a little while in gear and it would get power back. This made me think bad starter but now nothing I do seems to help to help it along. I can just try in another 5 min and it may work but it will quit again
Help!
Old Oct 13, 2011 | 01:50 PM
MelWff's Avatar
MelWff
Check the battery connections at the battery, at the frame where the ground cable connects and at the starter.
Old Oct 13, 2011 | 02:12 PM
builder's Avatar
builder
My ground cable came off when bringing my car home for the first time. It came off the engine block. Aand because there was no starter shield in place, it contacted the solenoid positive post and melted part of the nut and threaded post.
Old Oct 13, 2011 | 02:17 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
the logical places to start looking
Old Oct 13, 2011 | 02:58 PM
ashes0's Avatar
ashes0
think I've found the problem and at least the temp solution, I had already looked and tightened battery leads but now decided to remove them. Ground wire where it attaches to battery has plastic melted all over contacts, cleaned it off and we got power.
Not sure why its so hot though
To 79 Corvette Power Problems
