76 which core support?
Old Oct 14, 2011 | 12:51 AM
Tim H's Avatar
Tim H
Default 76 which core support?
Im going to replace my rusted core support.
Im not going to run the factory shroud and it had the early support in it so does it matter or is their an advantage of running the late one verses the early design?
Old Oct 14, 2011 | 11:19 AM
MelWff's Avatar
MelWff
Well since the radiator itself has an early and late version the shroud has to match the radiator so it sounds like you have to stick with early.
Old Oct 14, 2011 | 01:10 PM
Tim H's Avatar
Tim H
Im going with an aftermarket rad so who knows what it will fit!
Old Oct 14, 2011 | 01:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The 76 supports varied by how the stock fan shroud attached and a jink for AC plumbing when the swap was made to the R4 compressors.
If you want to keep factory air and have the A6 compressor, use the early support. If you want to keep the factory AC and have the R4, use the late support.
If you are not keeping factory air and do not intend to return to it, and if you're set on an aftermarket radiator, use the support recommended by the manufacturer of your radiator.
Regardless of who makes your radiator, you will still need the support seals.
Old Oct 14, 2011 | 05:02 PM
Tim H's Avatar
Tim H
I think i will wait until the rad comes in and see how it fits the early support i have now and then go from there.
I already got rid of the air and the broken shroud.
After i get it all done i will post pics and specs to maybe help out someone else.
Old Oct 16, 2011 | 11:47 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Willcox
To 76 which core support?
