wiper cover?
Old Oct 14, 2011 | 08:29 PM
McVette's Avatar
McVette
Default wiper cover?
hey guys I want to know if there should be something covering this section up on my vette or is it something you really dont need to have.....I seen where u can buy a piece to go over it, just trying to start to get ready for some winter projects here.....
[IMG][/IMG]
Old Oct 14, 2011 | 08:41 PM
corvetteload's Avatar
corvetteload
Thats it, pretty isn't it?!?!?!?!
Old Oct 14, 2011 | 08:46 PM
McVette's Avatar
McVette
WOOW ok thats good and bad ..........lol I was afraid that the PO had removed something and not replaced it....so I guess thats the good part.....lol the bad part is that it really looks like it is missing something...hahahah
Old Oct 15, 2011 | 06:18 AM
dgood's Avatar
dgood
nothing missing. You can buy a wiper cover for it for like 50 bucks from one of the corvette vendors
Old Oct 15, 2011 | 10:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by McVette
...I want to know if there should be something covering this section up on my vette...
No. What you see is what you got from St. Louis -- only cleaner.
You need ignition sheilding for the distributor.
Old Oct 15, 2011 | 12:34 PM
kdf1986's Avatar
kdf1986
I didnt like this area on my vettes so I bought the black plastic wiper area cover from a supporting vendor. I really think it cleans up the area and hides the internals of the wiper system.
kdf
Old Oct 15, 2011 | 08:56 PM
McVette's Avatar
McVette
yea Mike i noticed that on a couple other vettes i have seen that they had ignition sheilding for the distributor I thought it was just for dressing it up some....is there a different reason for it?
Old Oct 15, 2011 | 10:27 PM
CQRT's Avatar
CQRT
Use a brush to loosen up any debris, then vacuum out dirt/leaves. Then spray tire foam liberally in there . . .there's really nothing you can hurt. You can either wipe it to even it out - -or let it dry. A couple of coats and you'd be amazed how it improves the area.
As noted, you can buy a cover for it, but it's not the best designed area on our C3s . . .IMO
Old Oct 16, 2011 | 09:20 AM
U17's Avatar
U17
I have the cover.. Helps the looks a lot ...
Old Oct 16, 2011 | 10:27 AM
Easy Mike's Avatar
Easy Mike
...is there a different reason for it?...
Interferece. Without the shielding you can pick up ignition noise, especially in the AM band, from the HEI. Usually much less or no interference in the FM band without it.
Old Oct 16, 2011 | 01:56 PM
McVette's Avatar
McVette
Oh k thanks there Mike
Old Oct 16, 2011 | 05:28 PM
vettebuyer6369's Avatar
vettebuyer6369
I had one on all my later C3s. I think its a no brainer. Fits perfectly, doesnt affect the wipers, very secure with 2 screws. Much better looking than trying to make that junk catcher area look better.
Old Oct 16, 2011 | 06:58 PM
McVette's Avatar
McVette
thanks for posting pic 5869....really does look good
To wiper cover?
