transmission service
Old Oct 26, 2011 | 11:22 AM
rzkas's Avatar
rzkas
Default transmission service
i have a 82 corvette and i want do transmission service. I need DIY instructions. can this job be done with floor jack or it has to go to a shop with hydrolic lift? What parts materials do i need to do this job? What transmission oil do i need to buy?
Old Oct 26, 2011 | 11:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase one of the How To Rebuild Your 700R books. Owner's manual lists what transmission fluid to use. Dexron II probably, but don't quote me on that.
Old Oct 28, 2011 | 07:53 AM
crossfire1982's Avatar
crossfire1982
It could be done with the car on jack stands and probably with the front of the car up on ramps although it may be a little more crowded. The pan gasket and trans filter is available at most local auto parts stores (got mine at NAPA). You will need a LARGE drain pan to catch the fluid when you first lower the pan. When you pull the old filter off of the bottom of the trans, make sure the plastic sleeve on the filter neck comes with it. If it sticks, use some kind of small hook tool to pull it out, just dont do any gouging in the process. There is a torque spec for the pan bolts but I'm not sure what it is. There should be an instruction sheet with the service kit.
Old Oct 29, 2011 | 02:40 AM
rzkas's Avatar
rzkas
ok thanks.
To transmission service
