C3 Handling / Ride Vs C5?
Scott
What's needed is an objective measure. A good standard of handling is the Road & Track slalom course. 77 w/FE-7 High Perf. suspension set a new record in 77 with 63.6 mph "hampered by stock air pressures". Surprisingly, R & T did not try or publish performance with increased air pressure. They were aware stock air pressures were meant to keep the less astute out of the weeds.
Later matched by a Ferrari 512BB.
The high heavy rear glass hurt 78. 84 Corvette (however not all C4s) did better. The primary advantage of C4 being better tires. So many complained about the 84 stiff suspension that rates were reduced.
For reference, Mario Andretti turned 63.4 in a 1999 Corvette.
Scott
I loved my C5 but as many have said, it is not a classic Vette. I would never have taken it to a car show as the view from behind the wheel out is the best. I figured nobody would really want to see it in a car show hen you could just go to a dealer and see the same thing.
Because I will use the car very infrequently, I will do suspension mods in steps and see what I like. Of the four C3's that I had I never really disliked the handling. It was just that the C5 is so much better. I can live with a "driver's car" that requires more driver input. Sometimes that is a more fun ride. Hell, I drive a lifted truck most of the time and it certainly is no sports car!
Back to the question, you will never get C5/6 level of comfort/performance out of a C3 Vette but, the ride isn't all that bad if you stay with factory engineering. I have a 72 LT-1 with F-41 suspension set-up, it ran autocross times right there with our old C5 Z06 with both being on Kuhmo V710 sticky tires (we sold the C5 for the new C6 Z06.)
One thing the C3 will never equal is the comfort of a C5 Vette, but with the right parts it will handle pretty well. I am a big fan of Chevy engineering and had a basic F-41 suspension on my 72 LT-1 and the only good performance mod was a Borgeson steering box. I'm not a fan of retro fit transverse leafs in the front, dual mount rear springs or rack&pinion steering systems, if you want those go with a C4/5/6 Vette. I like steel 7-leaf rear springs (only the ones sold by Eaton Spring in Michigan), Bilstein shocks, and good alignments on a rebuilt chassis (Moog parts only!)
You have to be willing to work on your C3 Vette yourself as paying a shop to perform the tasks required to rebuild it will net you an investment that is more costly than the Vette is worth. The C3 needs to have a blueprinted rear differential, and quality parts in the suspension. There are many aftermarket products I wouldn't use on my Vette but many here champion their use, I think some are so poorly engineered as to be borderline dangerous and many Vettes these parts are found on are "garage Queens". I drive my C3 Vette over 5K miles a year and the Vette is pretty dead reliable.
I guess in the end you have to ask yourself if your willing to make the commitment to making a better Vette, if not, go with another C5 (sometimes I miss our C5 Z06, in many ways it was a far better balanced Vette than the C6 Z.)
Just grab you one and research and add what you want a bit at a time. Sounds like you need to stay away from the BB because of the heavy front end weight would really effect your handling.
I will be doing all the work myself (I built the '34 coupe below as well as many others) and this will be a play / hobby car so I can take my time and do the research.
One of the things I really liked about the C5 was its ability to double duty as a long distance traveling car. With close to 30 MPG and the creature comforts it was awesome on long trips. I guess the C3 would be more of a blast around local car so I'm not so worried about the ride.
No matter what I do it will handle and ride better than my hot rods!
I don't mind more power in the old Corvette, but I want the experience of my '69, or my '66, or my '58 now and then.
i kept my car stock (but improved-tuned) and took it to the racetrack : no big handling difference in respect to my Porsche Boxster.
thread starter read here :http://forums.corvetteforum.com/c3-t...ay-report.html
In certain situations the Vette gives me even a better handling-feeling than the Boxster.In some other not ( steering box unsolved issue i think , even if i went for the best one -gary ramadei made). I think i should go for rack and pinion but i like to keep my car stock
If you want the "simple answer" to the question that's it right there.A C3 will never be a C5............but it can be just as much all around fun to own and drive.
My 79 Vett has the complete VBP ultimate package ( shocks, sway bars, urethane bushings, front & rear springs, lowering kit etc. etc.), with off set trailing arms and a front spredder bar. Up grade brake kit.17 x 9 wheels and 275 x 40 x 17 Wheels.
[IMG]
[/IMG][IMG]
[/IMG]Did you use the Performance Plus System Full Kit from VB&P?
