Removing Door Panel
Old Nov 4, 2011 | 01:31 AM
USMuscle's Avatar
USMuscle
Default Removing Door Panel
I'm going to be changing out the locks and handles and will need to remove the door panels. Do these panels come off easy or are they a pita?
I'm sure there is a thread about removing them, but I had no luck with my search...
Old Nov 4, 2011 | 01:39 AM
milo30's Avatar
milo30
easy and straigt forward removal.
Old Nov 4, 2011 | 10:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Trim screws, a couple of brackets, and velcro. Do you have the assembly instruction manual (AIM)? AIM has a diagram of how the panels were installed, door handle, window crank, etc.
Old Nov 4, 2011 | 10:43 AM
garage-ghost's Avatar
garage-ghost
Here's a neat tip on removing the window crank.
http://toolmonger.com/2009/03/03/how...-the-easy-way/
Old Nov 8, 2011 | 10:18 AM
Big Block Dave's Avatar
Big Block Dave
The door panels are easy...if you mean outer door handles that you are replacing, well thats the pain in the *** of this whole deal!
Patience, and small hands are ideal for this job. I have neither, so it was alot of fun!
To Removing Door Panel
