what?
Old Nov 8, 2011 | 03:02 PM
udornf4's Avatar
udornf4
Default what?
I saw a fella selling a '73 on this forum (thread closed). It was advertised that it had a "M40" - What is an M40?
I'm thinking a TH400 and a miss-print?
Old Nov 8, 2011 | 03:04 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
M40 is the option code for the auto trans.
Old Nov 8, 2011 | 04:24 PM
udornf4's Avatar
udornf4
OK.
I didn't know M40 = Auto
One would think, maybe A40 would be for the Auto - but GM has their own way of codes...
thanks!
Old Nov 8, 2011 | 04:43 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
OK.
thanks!
RPO codes. M is used for transmissions. L is used for engines, and so on. you should pick your self up the Corvette Black Book by Mike Antonick
Old Nov 8, 2011 | 04:50 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
the most handy of pocket sized reference materials. since you probably don't want info on the newest of corvettes, you can usually find a used one on amazon or ebay for around $10.00. even if y ou want the latest and greatest version with the 2011 (or 2012) information it is under $20
Old Nov 9, 2011 | 10:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
M40 was the option code for the TH400 the years it was available.
Old Nov 9, 2011 | 03:52 PM
bobbarry's Avatar
bobbarry
And M38 was the usual code for the TH350, across divisions.
GM had traditional letter prefixes for certain categories of equipment; here are a few according to my failing memory:
A= Interior
C= Climate Control (C60= A/C)
G= Axle
L= Engine (L36)
M= Transmission (M22)
P= Wheelcovers (PO1)
To what?
