Can anyone tell me...
Old Nov 10, 2011 | 04:28 PM
pancake's Avatar
pancake
Default Can anyone tell me...
What this is? It's hanging from a brown wire with an inline fuse and a yellow wire from up near the fuse block on the driver's side. The car is a '78.
Also - The low and medium fan speeds do not work. I replaced the blower motor resistor and that didn't help. I used a test light and checked the power at the resistor on the medium and low speeds and power was there. I guess I should've used a multimeter to see what kind of voltage was there. So I'm assuming that it's not the switch but not sure where to look now??
Thanks!!
Eric
Old Nov 10, 2011 | 04:59 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
That little board gets plugged into the fuse panel in place of the wiper fuse if you have intermittent wipers.
It IS a factory thing, as bubba as it looks.
I believe it's in the harness regardless of whether you have regular or the intermittent wipers, just tucked out of the way if not.
A 1978 ONLY thing.
As for the fan speeds, I'd open up the AC relay on the firewall and lightly sand the contact points.
Old Nov 10, 2011 | 05:53 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
A 1978 ONLY thing.
that is exactly what it is. it plugs into the fuse box like a relay would. it is definitely factory as cobbled as it looks.
Old Nov 10, 2011 | 06:08 PM
pancake's Avatar
pancake
Oh, ok. My wiper switch has a pot on it like it should have delay wipers.. I don't like driving it in the rain, anyway, since showering more than once a day is a waste of water. Be green!
I'll try sanding the contacts on the relay, too. Thanks!
Old Nov 11, 2011 | 06:17 PM
pancake's Avatar
pancake
I cleaned the contacts in the ac relay and now I have fan speeds other than high! Thanks a million!
Now onto figuring out what's broken with the window regulators..
Old Nov 11, 2011 | 07:28 PM
KapsSA's Avatar
KapsSA
Just passing on advice given to me last summer! Glad it worked for you, too.
To Can anyone tell me...
