Fogging your engine?
Old Nov 12, 2011 | 08:58 PM
spf72's Avatar
spf72
Default Fogging your engine?
OK this may be a weird question but I can't remember ever reading anyone doing this so I thought I would ask. Last week when I was putting my boat away I went through all of the steps including spraying fogging oil in the engine through the carburetor and then through each spark plug hole. For those of you with boats you know this is the "required" technique for putting your boat up for the winter. The point of the fogging oil is to coat the cylinder walls with oil for the winter sleep. In the spring it smokes like crazy for a few minutes and then runs great. My boat engine is a marine version of a Chevy 350 with most of the parts the same as a auto version.
Why is this not a standard procedure when we put up our cars? Do any of you do this today?
Old Nov 12, 2011 | 09:03 PM
Mike Ward's Avatar
Mike Ward
Why? It's a waste of time for 6 months of storage.
Old Nov 12, 2011 | 09:04 PM
RescueDad's Avatar
RescueDad
My car sat for about 20 years before we started it up this summer. But before we started it, I pulled the spark plugs and fogged each of the cylinders and manually turned the motor over. I just put the car up for the winter but did not fog the engine. Of course, the garage is heated so I don't think fogging is necessary in my case.
Old Nov 12, 2011 | 09:17 PM
spf72's Avatar
spf72
Why would you say it is a waste of time? Is that your opinion or based on some facts? Nothing wrong with it being your opinion I am just wondering why car people, including myself, don't do it - is there something different about it that I am not seeing. Boats are also stored for 6 months but, according to my boat friend mechanics, close to 100% of them are fogged.
Of course it could be that fogging your boat is also a waste of time and money that people get convinced they need to because everyone else does.
Old Nov 12, 2011 | 09:22 PM
bkvette3's Avatar
bkvette3
IMO - not a waste of time - I fog my 115 HP Mercury outboard ever fall. Same thing with the lawn mower, weed trimmer, etc. Never any issues. I too wonder why this is never done to cars stored during the winter months. Can't hurt!!! As mentioned - coats the cylinder walls and internal parts. I have fogged cars that were put up for the winter months and never had any problems.
Old Nov 12, 2011 | 09:54 PM
RIO68's Avatar
RIO68
I got to pull my inboard engine and bore it because I didn't fog the cylinders. It sat longer than I anticipated because like the bumper sticker says "S--happens" and it pitted the walls and I had another job I didn't count on. Like Ins. worthless until you need it and then you usually don't have enough. Just my humble opinion---
Old Nov 12, 2011 | 10:03 PM
kf4cln's Avatar
kf4cln
No fogging needed in Alabama, we wear shorts all year long !
Old Nov 12, 2011 | 10:06 PM
spf72's Avatar
spf72
I guess this is my point/question. Three of us, so far, fog our boat engine but none of us fog our car. I just think that is strange.
I spend some time on a few boat forums and I have never seen any winter storage articles that don't include fogging yet I have never seen a car thread saying you should do it to your car.
I do have two engines on stands for a couple cars I am doing and I have squirted oil in the spark plug holes. It just seems the fogging oil would do a better job - talking myself into it!
Old Nov 12, 2011 | 10:39 PM
sly vette's Avatar
sly vette
Boat engines should be fogged due to the fact that the large majority of them are 2 cycle engines.
A 4 cycle engine should not need to be fogged if it being stored for a year or less.
I fogged my 5.7 in my Carver for years till a marine mech. that wasn't interested in taking ALL my money set me straight.
I haven't fogged it for 4 years now with no ill effects.
Old Nov 12, 2011 | 11:22 PM
alswagg's Avatar
alswagg
We winterize we over 300 boats a year, most all are 4 stroke. We only fog the engines of boats which are to be shrink wrapped, which are very few for us. We store just about every boat inside. In fact, new EFI with Catalytic convertes can not be fogged, or damage can be done by the foggin oil. It can also coat the MAP sensor's which can send an incorrect signal to the ECM. As for the Vette, I do not fog at all, as for our snowmobiles, we don't fog them either any more. I believe if you are going to store the engine for longer than 6 to 7 months fog it, but for normal storage, no real reason to. How long do cars set on a lot or a holding area without being started??? Al
Old Nov 12, 2011 | 11:54 PM
couperdecar's Avatar
couperdecar
Well I happen to fog my engine when I put it away. I don't consider it a waste of time. For those of you that think it is ,are you measuring the amount of wear that occurs when you start it? Sure you've "started it that way for 4 years". Big deal. A can is $4.50 and it last me 4 years. I say cheap insurance . Those of us with boats do it for 6 months -no questions asked! Why wouldn't we do it for our C3s. Take off your tin foil hats and spend $1 / year.
Old Nov 13, 2011 | 12:05 AM
noonie's Avatar
noonie
You inject it thru the pcv port in the manifold behind the sensors. Nowhere near enough to hurt the cats or o2 sensors.
Cheap insurance, wish I took the time to do it.
Old Nov 13, 2011 | 12:26 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
After over 10 years of corvette ownership I've never fogged my engine and have never had an issue starting the car in the spring.....I guess the question is based on my experience why do something that's not necessary.
Old Nov 13, 2011 | 12:38 AM
spf72's Avatar
spf72
I don't think it is a matter of the car not starting it is the wear that occurs when you do start it after sitting that long. The fogging oil coats everything including the cylinder walls with an oil that keeps moisture from doing damage and helps everything on start-up.
It could be that most folks start their cars several times during the winter where you never start your boat until you are ready to use it again.
Old Nov 13, 2011 | 12:48 AM
Mike Ward's Avatar
Mike Ward
In my current 'long term ownership fleet', I've owned my Corvette since 1990, am the original owner of a '79 Gold Wing with well over 150,000KM on it and have various other 2 and 4 stroke '60s vintage bikes and snowmobiles, some I've owned since '74.
None has ever been fogged. All run perfectly. Fogging the engine simply prevents the rings from sticking to the cylinder walls, nothing to do with lubrication.
No tin foil hats here.
Old Nov 13, 2011 | 12:51 AM
gq82's Avatar
gq82
Well since I'm talking about a fairly large sample of time and the fact my car uses/burns no oil during the year you'd be hard pressed to convince or prove to me there is any significant wear occurring during my spring startup.
BTW, I don't start my car during winter storage....that's probably the worst thing you could do.
If your happy fogging your engine every fall knock yourself out....again from my experience it's not necessary.
Old Nov 13, 2011 | 07:37 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have never "fogged" the engines in my Corvettes and never had an issue. I have had my 65 for 40 years with no issues. Of course I try to drive them as weather and road conditions allow, but there have been nasty winters when the cars sit for prolonged periods.
I also have a Donzi (boat). It has a fuel injected 350. I don't fog that either. I change the oil, change the outdrive lube, drain the block, fill with anti freeze, fill the gas tank and pull the battery. It fires right up in the Spring with NO SMOKE SHOW and no fouled plugs.
To Fogging your engine?
Old Nov 13, 2011 | 08:36 AM
garage-ghost's Avatar
garage-ghost
I've been storing cars for the winter for over 30 years and my opinion is that length of time in storage and dampness of the storage area determine weather fogging is necessary. In a heated garage for 6 month storage I think fogging isn't necessary. Storing a car in a dirt floor, unheated garage for 6 months or longer I would definitely fog it.
Old Nov 13, 2011 | 12:41 PM
7T1vette's Avatar
7T1vette
If a boat, car, snowmobile, etc. will be stored in an open environment near water for the winter, fogging is beneficial. If any of the above are stored inside and in a non-damp environment, its a waste of time.
However, unless it is detrimental to the emissions system or engine control system, fogging can't really hurt anything.
Old Nov 13, 2011 | 12:44 PM
Mike Ward's Avatar
Mike Ward
Cats are downstream of the engine.
