OK....so I have this beautiful 73 sitting in my garage awaiting my restoration attempt. I have a limited tool supply and I'll need to beef up my collection. My wonderful wife is asking for a christmas list. What are some of the must have tools (i.e. tools worth owning, not renting or borrowing)? I have a good mechanics tool set with basic sockets, wrenches, screwdrivers. I have a basic jack and stands. How about air tools? I have a compressor and a basic impact wrench so far. I plan to do as full a restoration as possible, hopefully with an engine rebuilt included.
Specifically, I'll need a torque wrench (or two). What torque range will I need?
And before the first wise guy says it, no, I can't ask for a restored C3 for christmas.
Buy quality and you only have to buy once. Cheap tools don't last and they only cause greif in the long run. I keep a snap on catalog with my other auto lit just to pull it out before Christams (circle what you want and leave it where she can find it). If you're doing a full restoration, you can't have enough tools. I've been collecting tools over thirty years and I still come up with things I need.
I do believe using the 'search function' has become a lost skill. That's too bad.
I had a specific question about a torque wrench range that I did not find by searching. I figured I'd expand it to a general tool question. But thanks for beating me up on how to use a forum. I always appreciate that...
i bought an impact wrench from sears, a 500 ft/lb model. beat it to death on all the rusty bolts(it actually broke) and took it back and got a new one at no cost. i felt bad about that, but not for too long. you'll need two torque wrenchse, a 1/2 " that goes to 100 ft/lb, and a 3/8" that goes to about 70 ft/lbs.
What size/brand compressor do you have or would anyone recommend. I'm getting ready to hit up Sears this Black Friday. Initially I was considering the 20gal or the 26 gal version. Then I read that they may be too small and will need to recharge too frequently. Should I go with the 30gal or is it overkill? I believe they all have at least a 125psi maximum.
I also have read that Craftsman quality is falling. Made in China, compressors leaking, blowing motors, etc. Any personal experiences.
As for the impact wrench....should I look for a 400 ft/lb minimum to get all the rusty bolts off? 2 days left....Im excited! Going to be purchasing a bunch of new tools.
I have a 30 gal, 6 or 6.5hp craftsman. I've had two issues with it. First the cooling fan imploded on me. Happened right when I was blowing out the sprinklers at the house. Had to have my father hold a desk fan on it while I finished the job. The second is the drain plug at the bottom always leaked. I replaced that. The replacement part was much more substantial than the original, so they obviously realize the original was junk.
As for sizing it right, it all depends on what you plan to do. Every tool has an minimum scfm rating at a particular pressure. And the compressor has scfm ratings over different pressures (obviously higher at lower pressures). As long as you compressor can handle it, it will be fine. Spraying usually has the toughest requirements which is how I wound up with a 30gal. I was spray finishing my kitchen cabinets.
I've liked every suggestion so far. I'm not sure what type of restoration you're planning on, mine was to meant to preserve the car for a number of years.
There were so many small pieces of metal that I wanted to clean up, but paint stripper and scrubbing weren't an option. Sand blast cabinet to the rescue. Then paint or POR-15 and it's as good as new and looks like it.
It would make a perfect addition to that air compressor you're getting. Get the biggest one you can. I bought the 33 gallon one but planned on using to blow out my sprinklers, it's worked great for many years.
I ran a 30 gallon compressor for years. When using a die grinder is was not enough. It slows down quite a bit and the compressor runs constantly. A blast cabinet there is no way a 30 gallon can take care of it. I worked a deal and now have a 6 HP 60 gallon. No more air issues. It is even a little small for constant blast cabinet usage but does great for small parts. Look at the CFM usage of tools at 90 psi and make sure your compressor has enough air to keep it suppplied. I have a pretty good array of air tools. The impact will not always break a bolt loose. You may need a long 1/2 breaker bar and i keep a 6 foot pipe near by for those really stubborn bolts. I have been collecting tools for 30 years now and am busting the seams of my tool box. Need a bigger tool box. My wife does not understand why though.
This will be my first compressor so my knowledge and previous usage is limited. I see you mentioned the 6HP rating.....the Craftsman at Sears say 1.6HP. Are there different ways to report HP or is this really 1.6? My friend has this same one but in the 26gal version and is sufficient for the usual jobs on his cars. I will most likely be picking this one up.
For a compressor, tryt to stay away from "direct drive". They are noisy and have reported problems. With horsepower ratings, look for "running HP" and "starting HP". You want to know the "Running HP". Also look for a compressor with cast iron compressor. Don't get aluminum. Here is a site that talks about compressors and what to look for.
This compressor is what they call an oiless compressor. They are very loud. They do not have a sperate head and motor the two are together. It will work fine for using an air ratchet or air gun and general usage. If yo uplan on using a die grinder or sander or a blast cabinet no way will it be enough. You are only 5.1 SCFM at 90 psi. Not nearly enough for tools that can run a long time. Short burst air tools will be fine. Look at the usage of the tools you arebuying and if any of them approach 5 SCFM it will not be enough. My 60 gallon gives somethinig like 13.5 SCFM at 90. If the compressor is going to run all the time it will be very loud if it is near you. Mine is pretty quiet but I put it in the corner of the basement so I can barely hear it run when working in the garage.
Call them up and talk to Matt Cain. He will help you figure out what you need.
Thanks for the info. Yea Ive been to this website and others which explain compressors in more detail. Unfortunately with a limited budget and with plans of only using the compressor for short burst tools, I narrowed it down to the Sears Craftsman. I do realize these are loud, my friend has one of these and have not had any problems.
I think I am somewhat limited to this option as the higher end compressors are just too expensive and I probably would not use them to their full potential. Now if I can just decide whether to get the 33gal or the 26 or maybe even the 20......
BTW...sorry for hijacking the thread but I guess this is "tool" related
I wouldn't call it hijacking at all. This is the type of discussion I was hoping for. (no thanks to those that whine that people don't know how to search)
The compressor discussion is interesting. I hadn't thought about it much. I thought I had a decent amount of capacity in my 30 gal, 6hp craftsman. I wasn't thinking about it being too limiting, but I guess I'll have to look into this. I have no plans to replace my compressor, but I will now check the specs and see what I can run with it.
