So right now I have an 81 original 350 engine with a new cam, intake, carb, distrubuter, headers true dual exhaust with a th350 transmission. ( I have not touched the heads yet)
note: I took off ecm, egr,no catalytic converters
My question is I am looking for more power what should I do?
I was thinking about 383 stroker kit?
or maybe a turbo setup with the 350 I heard not to sure, pretty new still but with the 8.2:1 ratio since it is low I can put pretty good size turbo.
Any ideas or anything that would help me about would be appreciated! just looking for some feedback, difficulty, and what would be recommended I use the car pretty much daily
A turbo would be cool but expensive and the engine bay does not offer much room for the additional tubing and inter-cooler. I think a super charger would be the best bang for the buck and you should have room for everything. I am sure some other guys might recommend NO2 but I am not a fan of refillable horsepower. Let us know what direction you go.
The 81 heads will be your weakest link. Consider upgrading those before you go any further. I'm assuming that you already upgraded the exhaust. If not, do that before you touch the motor.
The 81 is the most anemic better ever.
The heads are terrible smog heads.
I got rid of everything on my 81. Immediately sold engine and horrid 3 speed automatic to a guy who needed a nice lowwww compression set up for his truck.
I bought a 383 short block and a new super T 10 four speed. Have a nice Howards lopey cam, wieand intake, holley carb, hooker headers and most important..........cast vortec heads.
...Any ideas or anything that would help me about would be appreciated! just looking for some feedback, difficulty, and what would be recommended I use the car pretty much daily
Better heads & rebuilding if "original" engine would help a lot.
Definitely change the heads. You can also change the rear gears to help wake the car up a bit. There's nothing anemic about my '81 engine anymore! Rebuilt with new cam and heads but stayed with a 355; didn't go with a stroker kit.
