I fixed the clock, holy crap!
Old Nov 28, 2011 | 11:31 AM
Jay-Dog's Avatar
Jay-Dog
Default I fixed the clock, holy crap!
Oh my God! I was fiddling with the clock, took it apart, lubed it here and there, and whalaa, it works. I wonder what the percentage is of working clocks in these old vettes? 10%? Funny, that now when you sit the car, you here tick-tock tick-tock. You just don't here that in newer cars.
Old Nov 28, 2011 | 11:49 AM
Manuel Azevedo's Avatar
Manuel Azevedo
Very cool!! I got mine working in the same fashion also. These cars are just way cool anyway you look at them!!!!
Old Nov 28, 2011 | 12:28 PM
garage-ghost's Avatar
garage-ghost
Congratulations!
My clock has always worked (39 years now)...never touched it except to set the time.
Old Nov 28, 2011 | 01:11 PM
iokepakai's Avatar
iokepakai
UMM! Here I spent 70.00 on a quartz conversion.Should have tried to just clean it to...Good Going!
Old Nov 28, 2011 | 02:57 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Yup, fixed mine too. A little compressed air, some WD40 and it started running in my hand. Been 5 years now and still going strong.
Old Nov 28, 2011 | 03:01 PM
Roco71's Avatar
Roco71
I am inspired ... going to give it a try myself.
Old Nov 28, 2011 | 05:33 PM
Jay-Dog's Avatar
Jay-Dog
Yeah, like you said, it started running in my hand - freaked me out! No power to it. It ran for a bit this way, then, after hooking it up in the car, it's been going for three days now.
Old Nov 28, 2011 | 07:09 PM
08vycpe's Avatar
08vycpe
The old analog clocks have a set of points that, when making contact they "spring apart" creating the rewind. The tick you hear every two minutes or so is the points making contact and then springing apart again.
In addition to lubing with a light oil, it's important to use some very fine emery to clean the point contacts just as you would with your distributor points. The points fail because electrolysis transfers metal from one side to the other until it can no long function.
Old Nov 28, 2011 | 08:08 PM
outlawkinser's Avatar
outlawkinser
My clock has always worked and mine is in storage for 6 months of the year with NO battery. In the Spring when I get it out of storage; just install the battery, adjust the clock and it's good to go.
Mike
Old Nov 28, 2011 | 08:11 PM
7T1vette's Avatar
7T1vette
That "springing apart" is the rewind solenoid doing its job. Every two minutes [or so] those contacts come together. That connects the solenoid into the circuit. The solenoid then actuates which causes the spring to wind. As the spring unwinds, the contacts get closer and closer to touching. When they do, REWIND! Neat mechanism...when it works.
Old Nov 28, 2011 | 08:42 PM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
My 1980 clock works. I love hearing the sound of the clock when I am in the car. But I love grandfather clocks; which make those kinds of sounds all the time. So I am biased.
Old Nov 28, 2011 | 09:10 PM
mrmagrath's Avatar
mrmagrath
I used a writeup I found on here to resurrect mine from the dead. I used CRC CO Contact cleaner to clean the mechanism, some tissue paper to clean the points, and some WD40 to lube it up. Goes like a champion! Only problem is the adjuster gear has come away from the adjuster shaft. I have to sort the oil pressure gauge, so it's on the ever growing to-do list!
Old Nov 29, 2011 | 01:37 AM
C3-PO's Avatar
C3-PO
Default mines been dead ....
my '80 clock had worked for a little over a year, the contacts burnt and the spring stretched itself out to the point where it won't pull the contacts back together. took it apart and cleaned it up and it worked for two months after that. i've worn a watch for the last 29 years and it doesn't bother me at all.
Old Nov 29, 2011 | 03:07 AM
Muddywaters's Avatar
Muddywaters
Exactly! Muddy
To I fixed the clock, holy crap!
