Dash Pad
Old Nov 29, 2011 | 09:53 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Default Dash Pad
Hey Guys,
My dash pad needs to be replaced. Does anyone have ideas for getting a replacement? I found a few on vender sites, but I was hoping to find a pick apart place near by, or someone who has a spare, etc.
It needs to be black. I spend the majority of my time in Tipton and West Lafayette, IN.
Thanks.
Old Nov 29, 2011 | 09:59 AM
Hardway's Avatar
Hardway
Finding a good dash pad at a salvage yard will probably be impossible. You are better off buying a brand new one from one of the vendors. The dash pad that is offered by Wilcox has received good reviews. It is supposed to have more material that makes up the internal structure and support as well as having minimal flashing that needs to be trimmed off. Someone recently had a post about installing one of their newer dash pads and had pictures as well.
Whichever route you go just take your time installing it. The more time you take the better the final fit and finished look will be.
Old Nov 29, 2011 | 10:00 AM
Slotehog's Avatar
Slotehog
It doesn't necessarily need to be black. I had success using dye to get a doeskin dash dyed black. You can't tell it was ever as beige as doeskin.
If you go with a used dash (significant savings versus buying a repro) hit up the search button on prep and which brand of dye to use. Good luck.
Andy
Old Nov 29, 2011 | 10:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Corvette Central is a little north of you in Sawyer, Michigan.
Willcox is south of you in Jeffersonville, Indiana. Why not keep it a Hoosier thing?
Old Nov 29, 2011 | 10:43 AM
Roco71's Avatar
Roco71
Is your dash cracked or broken or just the padding?
Old Nov 29, 2011 | 10:54 AM
~Stingray's Avatar
~Stingray
I will have to look at it again more closely, but I thought the dash pad was cracked.
Old Nov 29, 2011 | 11:01 AM
427basketcase's Avatar
427basketcase
I had real good results with my original dash and a replacement "Cap"
Instead of installing it over the cracked old vynal, i ended up peeling the old brittle vynal off the entire dash, and installing the cap.
A little heat gun work afterwards and it looks factory.
all of this for right around $100.00, and about 2 hours of labor. It fit just like it should too.
Or you could spend upward of $400.00 for a Chineese repop.
Old Nov 29, 2011 | 01:36 PM
commander_47's Avatar
commander_47
I would like to see a picture of your dash.
Mine has two one inch rips on either side of the map light above the center dash panel.
Short of 400 for a new dash I'd like to fix it.
Old Nov 29, 2011 | 01:53 PM
427basketcase
I'll take some pics this evening and post them
Old Nov 29, 2011 | 02:09 PM
CQRT's Avatar
CQRT
http://www.ecklerscorvette.com/corve...1970-1976.html
Old Nov 29, 2011 | 05:20 PM
sweeet76's Avatar
sweeet76
A friend just covered his with material from a fabric store for 9.00 plus 10.00 for spray glue. The trick was to start from the center and work tightly outward toward the outside. He said he used a heat gun to help form the corners. Looks great and since I'm not an expert, I would never know the difference. For less than 20.00, it might be worth a try.
Old Nov 29, 2011 | 05:36 PM
~Stingray's Avatar
~Stingray
Could you get a few pics to show us how it looks?
Old Nov 29, 2011 | 08:59 PM
johnmb's Avatar
johnmb
Yes, please do! Both this and the pad "recap" would be great to see.
Thanks to you both
John
Old Nov 29, 2011 | 09:19 PM
mrmagrath's Avatar
mrmagrath
Big City Corvettes on eBay have good 2nd hand dash pads. I got mine from them!
Old Nov 29, 2011 | 10:03 PM
sweeet76's Avatar
sweeet76
I will get the guy to send me some pics to post asap.
Old Nov 30, 2011 | 10:20 AM
427basketcase
Here is mine, it is the original dash, without the original covering.
Like I said earlier, i peeled off the old brittle vynal, repaired the pad with some "Great Stuff" spray foam insulation, and sculpted it with a razor blade, then installed the cap secured with 3M spray contact cement.
A little heat gun work after it was back in the car, and here are the results.
This has been in use for 5 years now with no problems or issues
Before .....
After......
Old Nov 30, 2011 | 10:34 AM
commander_47
I have to say, that looks pretty good!
I tried using that 3m adhesive on a Taurus' door panel and it wouldn't stick well to the foam.
Yours came out nice
To Dash Pad
Old Dec 1, 2011 | 08:47 AM
~Stingray's Avatar
~Stingray
I am pretty sure it is just the pad. Here are some pics I took.
Sorry, it was really hard forcing my flash to come on.
Old Dec 1, 2011 | 10:33 AM
jcloving's Avatar
jcloving
I got mine from Ecklers. It is stronger and more flexible than my old one. The speaker openings are perfect. I had to flex the new one to get it in and it was perfect.
Old Dec 5, 2011 | 09:06 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We have the pads in the forum sale section 1st quality. And you'll save an additional 10 percent off with the sale code. http://willcoxcorvette.com/product_i...ducts_id=24338
