play in side yokes
Old Dec 8, 2011 | 08:51 PM
RR79CORVETT's Avatar
RR79CORVETT
Navigator
Default play in side yokes
When I took the rear differential out I noticed the side yokes move about 1/16". Is this OK? I am going to change the rear seals but didn't want to put the rear end back in without doing the yokes if the 1/16' is too much.
Thanks Rodney
Old Dec 8, 2011 | 09:04 PM
billcarson's Avatar
billcarson
rodney mine move around the same but don't pull out so the retaining clips are still in place.i have no issues whatsoever but i do not race the car so it may depend on how you drive it.you will hear all kinds of opinions on this topic and sometimes it will get ugly. good luck.
Old Dec 8, 2011 | 10:24 PM
zwede's Avatar
zwede
I'd replace them. They are surfaced hardened and once the hardened part is worn off they go pretty quick.
Old Dec 9, 2011 | 03:36 PM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Old Dec 9, 2011 | 03:55 PM
DRIVESHAFT's Avatar
DRIVESHAFT
You wont know if the yokes are worn until you can look at the tips.
A worn out posi clutch pack will allow excessive end play also.
Old Dec 9, 2011 | 04:23 PM
1974ta's Avatar
1974ta
Default Yokes
I thought my 70 was moving in and out in excess of 1/8". I picked up a dial indicator and found they were only moving .019 which is within spec. I thought the worst until I looked a bot closer.
Keep in mind that somewhere around 1974 the yokes were not properly hardened on the ends so they will wear out much faster. I remember reading another post that indicated there was a recall back in the day.
Don't guess and try to make as scientific evaluation as you can.
You can pick up a cheap dial indicator and magnetic base from harbor freight that will do the job.
Bill
Old Dec 9, 2011 | 05:54 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Bill
I don't know about any recalls, but my wife owned a '79 (bought it new), and the yokes on her car wore at the inside of the diff....
Old Dec 9, 2011 | 08:00 PM
RR79CORVETT
Navigator
Thanks everyone for the input.
Rodney
To play in side yokes
