Anti Theft thoughts
I know about LoJack, etc., but a real robber can quietly flat bed your Vette away. So, I am thinking maybe a LOUD alarm is the best method since nothing is fool proof, combined with a kill switch.
I figure a LOUD alarm will stop most robbers or at least cause enough racket to slow down the robber and / or make someone take notice. Maybe the robber takes a long time to find the kill switch and with all the noise just gives up.
Thoughts?
They now need to car jack you to get the key or jump in as it's running while your out at the ATM machine.
These are usually knucklehead misguided youths.
A pro is going to get your car regardless of precautions if its on his shopping list.
See Gone in 60 seconds for a real sense of insecurity. I know it's a movie.
I carry proper insurance and don't worry about it.
I don't advocate carelessness like leaving it in an airport parking lot while on a cruise and I know this is an exaggerated example.
I'll run to the Home Depot and I'll throw in Lowe's so there's no hard feelings and don't worry about it.
I drive and enjoy the car.
If you have to go some where and the car will be out of sight have a fuel cut off installed and activate it or a "kill switch" as these were in vogue in the 70's when hot wiring a car was fairly simple.
As for a car alarm, ah they don't even pay attention to my lights and siren, I highly doubt anybody gives a hoot when they hear another car alarm going off in a parking lot.
Again, if they want it they're going to get it. Car alarm goes off they cut the battery cable and flat bed it. Any body questions them they say they're emergency road service and car owner called for service/tow.
Car gets flat bedded and you get a check from the antique insurance provider you chose to insure your former ride.
Then you pick out another vette in a color you haven't owned yet.
May sound cynical but I'm a realist so just giving you a real world answer
It's like the people that go out and get a home alarm system after they are burglarized. Well they will never be burglarized again according to statistics with or with out the alarm.
Disabling the car is the best prevention.
Marshal
And yes, most people will look at car alarms going off, especially if its in the middle of the night. Well at least I take notice. But if your car alarm is notorious in your neighborhood for false alarms, then nobody will care. Key is to have layers of security.
My daily driver is a big threat and I have a lot of layers of security on the car. For instance I took off the hood release cable at the usual location and relocated it somewhere else in the car. So when a pair of theives break in, the alarm goes into chirping warning mode for 3 seconds meanwhile the theif already has the hood popped and looking to clip off the battery power.
Put a nice backup battery on your aftermarket alarm, but keep it hidden in an abnormal place. A good spot for the C3 is behind the rear panel towards the side. Run all the wires under the carpet up to the main harness and tape off all the colors to that aftermarket alarm. Its obvious that 40+ year old cars didn't have bright colored wires going up into the dash.
Remember, layers, layers and layers. Along with common sense not to park it where you don't feel comfortable.
Might sound crazy but when it comes to old school cars, I don't even bother locking the door...if they are after it I would rather they try to take it gently than breaking stuff to get inside.
but, the Alarm speaker I used is Painfully High pitch and loud !
You will run away from the noise, you Do not want to be near this thing going off.
and its mounted with no easy access.
Thoughts?
THIS CAR EQUIPPED WITH AN IED STEP BACK FROM THE VEHICLE NOW
I just felt led sorry
Marshal
Thoughts?
1. Insured with Hagerty for $65,000.
2. Garaged at home with ADT home alarm in garage.
3. Will mostly drive to good local areas / resturants or car shows.
4. May take on a weekend trip to a Corvette meet.
5. May take a weekend trip to a resort type hotel with secure parking.
1) Always keep your parked car within sight! If you can see it, you'll be aware of any fools 'casing' your car.
2) Don't park it anywhere but your garage.
3) If you must leave the car somewhere other than your garage, have a battery disconnect so that you can easily cut the power to it. Tough to start without a battery hooked up. But, this 'option' always has risk of failure (refer to items #1 or #2 for better protection).
Here's another example where the people do it do a bicycle lock...same principle.
http://www.youtube.com/watch?v=9j4Dq...eature=related
If this is real and accurate and well known and not some kind of fake then it seems like:
Determined pro thieves can steal anything.........t appears
Lance P.
"Get back.......GET...BACK......GET THE F*CK BACK"
Lance P.
Magnavolt
http://youtu.be/uRNVxHPJ0hM
Trunk Monkey.
http://youtu.be/Ee3L9BQQ4Gs
But seriously,
I have an coded ignition key in my '74 but
If I'm going to be away from home for more than a few days,
I remove 3 wheels and store them away (It's up on stands ATM).
Also have quite a loud alarm fitted in my garage and CCTV wired in to it.
Oh yeah, and an Alaskin Malamute and really COOL
(armed
) neighbours.
Gav
