Clay Bar ?
Old Dec 14, 2011 | 07:28 PM
lonzoo's Avatar
lonzoo
Default Clay Bar ?
Have a 78 SA that was painted in 1998 and still looks very nice. I was wanting to obtain that shiny "wet" finish when I polish it out soon. I have read that the clay bar is the best first step to do that. However I do not know how the car was painted,with or without clear coat. So i was wondering if anyone has any advice on the use of clay bar as I don't want to ruin the finish.
Lonzoo
Old Dec 14, 2011 | 07:38 PM
mortgageguy's Avatar
mortgageguy
I've used it on single stage and clear coat with excellent results. Follow the directions and avoid dropping it. If dropped, throw it away and break off a new peice to work with. You'll love the results, especially on a car that has never been clayed.
Old Dec 14, 2011 | 07:43 PM
BKarol's Avatar
BKarol
A clay bar removes contaminants stuck to the surface. Make sure you buy a mild clay bar. AZ sells Clay Magic. No need to go for the hype of other brands. Bar will be blue. You dont want anything agressive and make sure you use a lot of lubricant.
If it drops on the ground, you need to go buy another.
Old Dec 14, 2011 | 07:54 PM
lonzoo's Avatar
lonzoo
Good info guys..thanks. Is it ok to use orbital polisher with it?
Old Dec 14, 2011 | 08:12 PM
Paul L's Avatar
Paul L
No!! Don't get lazy with electrical appliances. Do the job by hand and inch-by-inch wet with a mild or diluted dish detergent soap. Followed by a Zaino or other multi-step treatment. Once done properly it will last for quite some time. This car is driven.
Old Dec 14, 2011 | 09:14 PM
oldsarge's Avatar
oldsarge
Here is a how to video, that might help you out, on how to clay bar.
http://www.youtube.com/watch?v=yfEfLGL59GI
Old Dec 14, 2011 | 10:01 PM
BKarol's Avatar
BKarol
You probably have a clear coat but one way to check is to try some polish and see if you remove paint. It will show on your cloth. Try in a spot that wouldnt be noticeable. If so then you need to proceed with caution.
Using an electrical appliance is not being lazy. Depends on what you are trying to do. Removing swirls, scratches, etc. requires the right tools & products. I use a Porter Cable random orbit #7424 with yellow,orange,white, and black pads. Numerous degrees of polishes depending on the paint correction needed on the car I am detailing.
You didnt mention what kind of orbital you have so I think you should practice on your DD. Some are good for applying waxes and not much more. Use the clay bar, polish by hand , and wax. Should make it shine.
There are numerous detailing forums, and more products out there then you care to know and everyone has their favorites.
good luck.
To clear up a misunderstanding I in no way meant that you can use a clay bar with a PC. Its for polishing & wax.
Old Dec 14, 2011 | 10:56 PM
rod7515's Avatar
rod7515
I agree with Paul74, clay bar then use the Zaino products. I have tried many kits but the Zaino kit has given me the very best results. If you want the wet look this is it!
Rodney
Old Dec 15, 2011 | 09:45 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Meguairs has a clay bar kit you can find at walmart. I have used that for several years and couldn't be happier with the results.
If you never clayed before, its really not that hard; it just sounds complicated and a little out there. "I know, lets rub clay on my car; that will make it look great". I had the same thought process when I first heart about it. Give it shot, you will not be disappointed.
You will have to do it by hand. Once you see the kit you will see there is really no way to use a porter cable or any other buffer.
Old Dec 15, 2011 | 10:47 AM
l1dws's Avatar
l1dws
I have found that Griots makes the best clay bar. I like using Griots Speed Shine as the lubricant as you clay bar. Good luck !!!
Old Dec 15, 2011 | 12:15 PM
08vycpe's Avatar
08vycpe
All the clay comes from the same quary in Japan so who sells it doesn't matter. I agree with what others have said here; follow instructions and use Zaino or Rejex instead of wax.
Also keep in mind that if you use Zaino or Rejex over wax it will only last as long as the wax lasts. Best thing to do is strip the wax, clay bar and Zaino or Rejex as the last step. The car will wash easier and bugs are easy to get off.
RonR80's Avatar
RonR80
St. Jude Donor '09
First time with a clay bar , used mothers worked great just take your time .
Old Dec 15, 2011 | 01:43 PM
Frankenvette's Avatar
Frankenvette
I bought the meguirs kit about 3 months ago but have yet to use it. Now you guys have me motivated to get on it. I think I'm going to practice on my girlfriends Z3 vert.
Jim
Old Dec 15, 2011 | 04:02 PM
BKarol's Avatar
BKarol
FYI, a clay bar does not give your car a shine. It might look shiny because you are wiping off the lubricant & dirt with a cloth.
It is one step in the detailing process. You then either polish & wax or after the clay bar just wax.
Clay will "scrub off" wax protection. Some paint sealants are hard enough to withstand being cleaned with clay, but I would not assume the protection is still there.
Old Dec 15, 2011 | 07:08 PM
lonzoo's Avatar
lonzoo
You guys really know your stuff on this detailing. Looking forward to getting started.
Old Dec 15, 2011 | 07:24 PM
Paul L's Avatar
Paul L
Just keep the clay bar wet with a lube; diluted dish detergent or whatever. Even after a car wash, you will be amazed at what contaminants come off and make the clay dirty.
Old Dec 15, 2011 | 07:37 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I use 3M wax after a good clay barring... added about a foot to the depth of the paint...
To Clay Bar ?
Old Dec 20, 2011 | 07:48 AM
69small block's Avatar
69small block
Default wax
anybody out there ever used Pinacale wax Its all carnuba wax what about zymoil
Old Dec 20, 2011 | 08:34 AM
SteveG75's Avatar
SteveG75
Here is what I use after the claybar:
http://www.prowax.com/waxes/W-41_Yellow_Wax_Paste.html
It is pure wax, no cleaner, so the car has to be super clean prior to application. It goes on very easy, dries quick and is easy to buff out.
One clay bar session and one quick coat of W-41 wax gave me these results:
Old Dec 20, 2011 | 09:37 AM
BKarol's Avatar
BKarol
Pinnacle makes great products and you can purchase them through a supporting vendor Autogeek.
When it comes to Zymol you need to distinguish which one. The one selling at Target or this one :
http://www.zymol.com/zymolroyaleglaze44oz.aspx
Meguiar's #26 yellow canauba wax for over the counter is excellent also. I like P21s. There are so many out there.
