Cleaned up my wheels
Old Dec 16, 2011 | 07:49 PM
atikovi's Avatar
atikovi
Default Cleaned up my wheels
On a '82 CE, inside and out.
Took about a whole day between the removing, cleaning, balancing, detailing and installing again.
Old Dec 16, 2011 | 08:08 PM
elecriciandude's Avatar
elecriciandude
They look great. Love a clean look...........
Old Dec 16, 2011 | 08:46 PM
m and t's77's Avatar
m and t's77
Love that style rim.
Verona's Avatar
Verona
very slick!
Old Dec 16, 2011 | 08:55 PM
G-Sting's Avatar
G-Sting
Lots of elbow grease.
Excellent results!
Old Dec 16, 2011 | 09:23 PM
PUNISHER VETTE's Avatar
PUNISHER VETTE
I'm about 2 hours North of you so I'll expect to see you at my place in the morning around 9ish and you can clean mine for me!
Old Dec 16, 2011 | 10:07 PM
DrRCC's Avatar
DrRCC
Did you use any special cleaner?
Old Dec 17, 2011 | 12:26 AM
merc64's Avatar
merc64
I'm curious about this too. I've got to clean up the rims on my CE and hopefully they can come out close to yours. Did you use any type of specific wheel polish? My painted area isn't too bad but the aluminum/alloy part is going to take some work.
Old Dec 17, 2011 | 07:49 AM
atikovi's Avatar
atikovi
I used Meguiar's Super Degreaser and a scrub brush for the first two passes on the tires and wheels. Then for the inside of the wheels I used Bill Hirsch Miracle Rust Remover And Metal Prep along with a medium scuff pad twice as well as with a tooth brush in tight spots. Then rinced and dried and balanced with coated stick-on wheel weights mounted on the inside. Finished with Meguiar's Ultimate wax.
Old Dec 29, 2011 | 06:52 AM
jasperorr's Avatar
jasperorr
just a question, can i get c5 z06 rims on a c3? is the bolt pattern the same?
Old Dec 29, 2011 | 08:02 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Very nice clean-up job, and don't take this personally, but WOW, that's a LOT of balance weight on that wheel!
To Cleaned up my wheels
