C-3 tire size
Dec 20, 2011 | 08:41 AM
1st Gear
C-3 tire size
I am look for the correct tire size for a 1975 corvette with stock 8" rally wheels. I have been to several tire outlets and I get different answers. What are you running?
Dec 20, 2011 | 08:49 AM
All I know is that I will never go with 60 series tires again... 235x70's fill out the rear fenderwells much better then the 60's....
Bob G
64 72 & 98 Convertibles
76 79 88 (35th anc) Coupes
Dec 20, 2011 | 08:55 AM
Cruise-In II Veteran
GR70-15s were stock. 225R-15s would be close.
Dec 20, 2011 | 11:43 AM
Quote:
Originally Posted by
Easy Mike
The GR70-15 was the OEM size. Tires went to metric sizing in 1978, and the GR70 designation was replaced with P225/70R-15.
The metric sizing is still in use today, so P225/70R-15 is still the correct replacement size, for your 75's original GR70's.
Dec 20, 2011 | 04:24 PM
60-series tires weren't an option until 1978 when the body panels were modified for clearance.
Dec 20, 2011 | 05:10 PM
A 237/70 was a small suv truck tire if thats what you want.
If you won't go 255/60s that fit your car than get the right size 225/70s.
Dec 20, 2011 | 05:36 PM
Both 225-70-15 and 255-60-15 are within 1/4" of the same diameter, but the 255 has a 1 inch wider section width.
Dec 20, 2011 | 07:18 PM
larrywalk
That is indeed correct, but the OP said
original size for his '75 car. The 255/60s, as previously mentioned, were not available until 1978, and I believe first available on the Indy pace cars.
1975 ,
1976 ,
76 ,
c3 ,
chevy ,
correct ,
corvette ,
gr7015 ,
rallye ,
replacement ,
size ,
sizes ,
stingray ,
tire ,
wheel ,
wheels
