71 Back on the Road
Old Dec 28, 2011 | 01:18 AM
CraigH's Avatar
CraigH
Default 71 Back on the Road
Hi
After 6 months I have my 71 Vette back on the road.
Was a project to clean up the engine bay, rebuild front suspension with Speed Direct Semi CoilOvers and add a Borgeson steering box and .........
Not 100% finished but very close.
Before
After
Finished Stance.
Full details of the work here.
http://www.australiancorvettes.com/p...pic.php?t=6326
to
http://www.australiancorvettes.com/p...=asc&start=990
Old Dec 28, 2011 | 01:22 AM
rogman16's Avatar
rogman16
Awesome, looks great!! Love that color of blue... Have fun...
Rogman
Old Dec 28, 2011 | 05:57 AM
parkerracing's Avatar
parkerracing
What makes coil overs "semi"?
Old Dec 28, 2011 | 06:36 AM
UberLegend's Avatar
UberLegend
That's alotta work in 6 months.....well done
Old Dec 28, 2011 | 07:21 AM
DAVID SLUDER's Avatar
DAVID SLUDER
Really looks good, what paint did you use on the frame?
Old Dec 28, 2011 | 07:53 AM
V4motorsports's Avatar
V4motorsports
Absolutely beautiful stance!!!!! Love the way the tires fill the openings.
What wheel/tire combo?
Great work!!!!!
Russ
Old Dec 28, 2011 | 09:15 AM
Lupigiato's Avatar
Lupigiato
Old Dec 28, 2011 | 09:43 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You do nice work and it's good to see another 71 back on the road.
Old Dec 28, 2011 | 10:59 AM
oldsarge's Avatar
oldsarge
Looks great, well done !!!!
Old Dec 28, 2011 | 01:07 PM
rosslato's Avatar
rosslato
Ooh man great job, beautiful job on the suspension and engine bay. Beautiful color You made a vette better than from the day it left the factory, Kudoos to you
Old Dec 28, 2011 | 02:11 PM
BKbroiler's Avatar
BKbroiler
Wow. Very nice.
Old Dec 28, 2011 | 02:54 PM
Alan 71's Avatar
Alan 71
Hi Craig,
You've really done some VERY nice work on your 71!
I'll bet it really turns some heads as you go by.... it's a beauty!
Have FUN!
Regards,
Alan
Old Dec 28, 2011 | 03:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
A lot of work there. Worth the effort. Looks good.
Old Dec 28, 2011 | 04:16 PM
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
outstanding work. It was a nice car before, but now... wow.
Old Dec 28, 2011 | 04:31 PM
CraigH's Avatar
CraigH
Originally Posted by Alan 71
Hi Craig,
Have FUN!
Regards,
Alan
Thanks Alan
Your photos were invaluable in so many small details I had to put back to original.
While I have made a a number of changes away from stock with suspension, fans etc I have also tried to put many things back to stock where possible.
Craig
Old Dec 28, 2011 | 04:45 PM
CraigH's Avatar
CraigH
Thanks - I appreciate your feedback
I believe its because they use one of the original spring seating points rather than both ends of the spring being captive to the shock.
Got these after reading what gkull had done.
Heaps of height adjustment and meant I could get the vette to sit perfectly level
I used Killrust Enamel with some Hardener added to the mix. It was applied with foam applicators as well as some final spray finish in some areas. Given motor did not come out to do it spraying it all was not feasible.
A-Arms are powder coated in Gloss.
I still have a lot of the frame to do as i have worked it just back from the firewall.
Great work!!!!!
Russ
They are 18x8" Coy C5's with 4" backspace
Tires are Yokahama 245/45/18 Front, 255/45/18 rear.
To 71 Back on the Road
