Need help- desperate!
Old Dec 29, 2011 | 01:38 PM
Xliberater's Avatar
Xliberater
Default Need help- desperate!
This week I wanted to spend some time redoing my brake system by replacing the master cylinder, calipers, brakes, and hoses as they have been showing signs that they need to be replaced. Everything has been going smoothly until I tried removing the passenger rear caliper. One of the bolts holding the caliper to the rotor seems to be so stripped and rusted that I can't seem to get it to budge. I have tried everything from vice grips to pb blaster to a heat torch to try and remove this one bolt. Ive been working on this for 3 days now and beginning to lose my patience. Does anyone have any other suggestions to try and get it out? thnx
Old Dec 29, 2011 | 01:50 PM
fanmanbd's Avatar
fanmanbd
Are you saying that the head of the bolt is rounded?
Old Dec 29, 2011 | 01:56 PM
Xliberater's Avatar
Xliberater
Yes, very rounded, I got all the other ones out fairly easy but this last one isn't coming out
Old Dec 29, 2011 | 02:00 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You might want to try one of the universal grip sockets which are touted as being able to hold almost everything.
Old Dec 29, 2011 | 02:07 PM
fanmanbd's Avatar
fanmanbd
They sell sets for removing damaged nuts and bolts. Not sure if you can get an individual socket.
Old Dec 29, 2011 | 02:12 PM
Roco71's Avatar
Roco71
Sometimes you can take a metric socket about one size smaller than the standard and tap it (hammer) it over the round head and remove the bolt.
Got this tip from a old mechanic and it has worked for me in the past.
Old Dec 29, 2011 | 02:13 PM
RedZR's Avatar
RedZR
Years ago I purchased a 6 inch pipe wrench at sears and that thing has saved my bacon on many occasions ! Try that if you can get it positioned in there.
Old Dec 29, 2011 | 02:19 PM
fanmanbd's Avatar
fanmanbd
If you can get a pipe wrench in there you will probably need a pipe on the handle for leverage.
Old Dec 29, 2011 | 03:26 PM
Xliberater's Avatar
Xliberater
I just went out to Sears and got one of those grip tight sockets that are meant for extracting rounded bolts, but its so badly rounded that it wont grip onto the bolt
Old Dec 29, 2011 | 03:34 PM
7T1vette's Avatar
7T1vette
Stick a big-a$$ vise-grip on that bolt head...as tight as you can get it. Then put a 2 to 4 foot piece of 1" black-iron pipe over the part of the handle with the adjustment nut on it. Give it all you got! Once you break it loose, just replace that bolt.
Old Dec 29, 2011 | 03:39 PM
Mooser's Avatar
Mooser
My spindles are out right now so I can't go look.
Can you take the bracket off the spindle (with caliper still attached) and get it out to the bench where you can at least get at it better?
if it's not buried in the pocket like I vaguely remember, you might be able to weld a nut to what's left of the head (pull the caliper apart and remove the seals etc) and use that
You might be able to drill it out (undersize of course) and then an ez-out might break it loose at that point.
I'll have a look at the caliper when I go to the garage see if I can think of anything
Good luck
Mooser
Old Dec 29, 2011 | 03:47 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
Originally Posted by Xliberater
try and remove this one bolt. Ive been trying to get this thing out for about 3 days now and beginning to lose my patience with it.
Three days on one bolt. Now THAT is patience
By now many of us would have given up, thrown the tools back in the drawers, scrapped the project and started something else.
+1 on the pip wrench. When nothing else will grip those will grip tenaciously.
Old Dec 29, 2011 | 03:58 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Do you have an arc welder? You could weld a nut to it and then use a socket on that nut.
JIM
Old Dec 29, 2011 | 04:07 PM
Xliberater's Avatar
Xliberater
The problem is that the position of this bolt makes it quite difficult to reach with certain tools such as large pipe wrench. Unfortunately I have to go to work here in a bit so I'll check back once I get home. Thanks for all the quick replys!
Old Dec 29, 2011 | 05:03 PM
my 76 ray's Avatar
my 76 ray
Like Mooser suggested, I would try to remove the bracket from the spindle and get it to a vise where you can probably get a pipe wrench on it.
Old Dec 29, 2011 | 05:54 PM
sweeet76's Avatar
sweeet76
My biggest concern would be twisting the head off the bolt when you finally get a good grip on it. Good luck!!
Old Dec 29, 2011 | 07:29 PM
mad pad house's Avatar
mad pad house
I went through the same thing last spring.I ended up splitting the caliper and drillig down the centre of the bolts being careful not to damage the threads.Not easy but it did the job.Good luck.
To Need help- desperate!
Old Dec 29, 2011 | 08:11 PM
Xliberater's Avatar
Xliberater
how difficult is it to remove the entire assembly so I can work on it at the workbench?
Old Dec 29, 2011 | 08:40 PM
Procrastination Racing's Avatar
Welding a nut on is a very good idea if you have a welder. Two reasons, it gives you something to grip and the heat frequently will break it loose.
The idea of splitting the caliper and taking off both halves is good but you need the head of the bolt off to do that. So if all else fails, you can cut that head off and split the caliper so you can slide it off. Then you will have a half inch sticking out that you can grab to twist out.
At this point, there is too much metal in there to heat it all extremely hot and then apply an ice cube to the bolt. I think too much heat would be drawn from everywhere instead of the bolt shrinking.
At the very worse, take the entire trailing arm off and take it to a machine shop. They will get it out for you.
Old Dec 30, 2011 | 12:59 AM
Ray Y's Avatar
Ray Y
Can you cut 2 flat edges on the rounded head with a cut off tool, die grinder, dremmel, etc... so that the universal gripper socket will bite?
If not try what Jim (427 Hot Rod) recommneded and weld a nut on, even if its with JB weld, if you PB Blast soak it, it should come out.
