68 A/C Duct Removal
Old Dec 30, 2011 | 09:57 PM
54greg's Avatar
54greg
Default 68 A/C Duct Removal
How do you remove the driver side a/c duct?
Old Dec 31, 2011 | 12:48 AM
7T1vette's Avatar
7T1vette
Remove the lower steering column cover (1 screw); drop the bracket with the manual override valves on it (2 screws); remove one bolt on the mounting bracket for that A/C duct.
Then just separate the duct pieces enough to pull it out. Be careful not to bend that duct...it's expensive to replace it.
Old Dec 31, 2011 | 12:57 AM
54greg's Avatar
54greg
Thank you! When I removed the steering column cover and the manual override valve cover today I could not find the bracket for the duct. I'll try again tomorrow.
Old Dec 31, 2011 | 10:26 AM
7T1vette's Avatar
7T1vette
There is just one metal bracket (about 1" wide) riveted to that duct. The end of that bracket mounts to the bottom side of the steering column (if I remember correctly)...somewhere near where the interior light is mounted...with one small hex-headed bolt.
Old Dec 31, 2011 | 10:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
AIMs are handy things to have around.
Old Dec 31, 2011 | 12:01 PM
54greg's Avatar
54greg
Thanks all! Have a great new year
Old Dec 31, 2011 | 12:38 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Happy new years to you also! You may need to depress the brake pedal and or the clutch pedal to be able to drop the duct after all is disconnected. I'm not sure on all the C3's but on my 68 you do not need to take anything off or disconnect anything other than that one inch wide bracket shown in the above AIM.
To 68 A/C Duct Removal
