Shims Issue
Old Jan 1, 2012 | 05:14 AM
Vis's Avatar
Vis
Default Shims Issue
Hi Guys,
Im looking for some advise. Was driving my 73 Vette teh other day when i heard something fall out. I stopped and checked it was a shim.
Is it still ok to drive the car, would it cause any damage, is it dangerous, or am i best not to?
Old Jan 1, 2012 | 05:22 AM
jesse10886's Avatar
jesse10886
Go get the car aligned don't drive it till then jmo
Old Jan 1, 2012 | 05:56 AM
Vis's Avatar
Vis
Thanks Jesse. Is that something a mechanic has to do or can you take it to a wheel alignment place?
Howz the weather in Cali?
Old Jan 1, 2012 | 11:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Shim from where? A arms have shims; trailing arms have shims; body mounts; radiator support.
What type of shim did you find?
Old Jan 1, 2012 | 06:15 PM
Vis's Avatar
Vis
I beleive its a shim to the Trailing Arm Alignment Kit....according to Ecklers parts book there are 24 of them
Old Jan 1, 2012 | 06:42 PM
doctorgene's Avatar
doctorgene
Yes Sir; A lot of Alignment shops don't know Squat about replacing the trailing arm shims.
They want to bend the trailing arms to make them come out right. Take your car to a good frame shop, & have them do it right. The shim at the trailing arms have a carter key that should hold them from falling out. Sounds like someone has worked on this unit, that knows very little about them. Have a great day. Gene
Old Jan 2, 2012 | 09:00 AM
garage-ghost's Avatar
garage-ghost
Hopefully it's an extra one that was left sitting on the frame or elsewhere.
Old Jan 2, 2012 | 09:36 AM
luisv's Avatar
luisv
Trailing arm shims are held in place by a pin. If one dropped out, the others will soon if they are not all gone. Check into into...
To Shims Issue
