Catalytic converter
Old Jan 11, 2012 | 05:50 PM
bull dog's Avatar
bull dog
Default Catalytic converter
Have a question on my 75 vette would it help me get better gas miles if i take the catalytic converter off.
Old Jan 11, 2012 | 06:23 PM
zwede's Avatar
zwede
If it is the 37 year old original one: Yes.
If it is a modern one (within the last 15 years): No.
Old Jan 11, 2012 | 06:28 PM
terry82's Avatar
terry82
if your converter is plugged up then yes your mpg would go down.if its the orginal cat replace it .your bad mpg may have more to do with a lot of other things .what is your rpm at 60mph?if the rpm is high thats one problem.hows your driving habits?theres a lot to improving mpg.what mpg are you getting now?
Old Jan 11, 2012 | 07:37 PM
Paul L's Avatar
Paul L
Agreed. A high-flow, non-pellet type will work very well.
Old Jan 11, 2012 | 09:11 PM
zwede's Avatar
zwede
Case in point: I once had a '83 Cadillac Deville. It still had the original pancake style cat on it and the best I got on the highway was 22mpg. Replaced it with a modern free-flow cat and had noticeable better power and repeatedly got 26 mpg highway.
Old Jan 11, 2012 | 09:38 PM
bull dog's Avatar
bull dog
Default Cat
I thank i will take it off thanks you guys for the info.
Old Jan 11, 2012 | 09:46 PM
terry82's Avatar
terry82
take off the cat, then open it up with a long rod .put it back on zero cost.
Old Jan 11, 2012 | 10:21 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
You have to pass visual inspection here in NC with your '75, so they will be checking for a catalytic converter.
Old Jan 12, 2012 | 01:37 AM
vairxpert's Avatar
vairxpert
Just go all the way and get rid of that poser fake dual exhaust system.
Some headers with true duals, jetting, carb tweaking and timing advance kit will make a power difference you won't believe. As an added bonus mileage will go up as long as you're not having fun with the added power and it'll sound like a real car.
If you have emissions testing just get some new high flow cats. If not leave them off and also ditch the smog pump for a few more HP, less weight and another boost in gas mileage.
I wonder what the trade off has been over the last 40 years of low emissions vs. millions of gallons of wasted fuel?
To Catalytic converter
