1982 Corvette Door Hardware Question
Old Jan 13, 2012 | 11:55 AM
scorpion18z's Avatar
scorpion18z
Default 1982 Corvette Door Hardware Question
Gentlemen, do any of you have any tips or procedures for removing the door opening hardware on a 1982 corvette? It seems awful tight in there and I need to replace the door opening assembly. Also, any direction when I might find the door opening asembly?
Old Jan 13, 2012 | 11:59 AM
blckslvr79's Avatar
blckslvr79
Removal is the easy part. Just wait till you try to reinstall it.
Do you have a person of small stature with tiny hands in the household??
Old Jan 13, 2012 | 12:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The assembly instruction manual (AIM) has diagrams of how the door opening mechanism was installed. Are you wanting to replace the door opening handle or the latch?
Old Jan 13, 2012 | 06:32 PM
scorpion18z
I want to replace or repair the, for a better word, handle. The spring has corroded to the point that it has broke and the "handle" does not return to the flush position (Pushing in on the handle will still open the door). It appears to be a removable assembly with two nuts and a rod connecting fitting. I have seen these assemblies at the Daytona Turkey Rod show held at DIS this past Thanksgiving holidays, but didn't know I needed one at the time.
Old Jan 13, 2012 | 07:52 PM
BKarol's Avatar
BKarol
At the top of the page you will see "search this forum", just type in door handle and can read all the discussions about replacing.
When it comes to buying a replacement you might want to read these threads:
http://forums.corvetteforum.com/c3-g...r-handles.html
http://forums.corvetteforum.com/c3-t...r-handles.html
Old Jan 14, 2012 | 10:57 AM
Easy Mike's Avatar
Easy Mike
Order the AIM. I'm betting you're going to want it for more than door handles.
Old Jan 15, 2012 | 09:47 AM
tjkcreations's Avatar
tjkcreations
I bought mine from AM-Autoparts on Ebay for $45.00 (pair).
Old May 20, 2012 | 05:08 PM
jimbil208's Avatar
jimbil208
have fun with the rear nut for the handle
Old May 20, 2012 | 05:28 PM
Mark G's Avatar
Mark G
There is a small spring clip you can buy which can be installed w/o removing the door handle.
Otherwise, I didn't find the removal/reinstall of the door hardware THAT difficult. It's tight, but take your time and use swivels and other tools as needed to reach the screws and nuts. Good luck,
To 1982 Corvette Door Hardware Question
