I have finally reached the point of restoring the interior of my 1968 (late, July 69) 427/435 coupe. I pulled the instrument cluster to begin restoring it. When I went to the various catalogs, it appears I have a 1972-1976 cluster! (Part #6491171-69 stamp on the bezel. Sigh.)
Questions:
Can someone send me a pictures of a correct 1968L cluster, including the rear housing of the instrument cluster? (I realize the last one may be tough ). I'd like to know if my rear housing is compatible with a correct 1968L bezel.
Would I get dinged on points if I replace the bezel with one for a 69? (grainy vs smooth finish)?
Thank you in advance for any help you can provide.
I'm sure that Mike Ward will inform you of the "official" word on how many points will be deducted for not having a '68 bezel; it is probably significant. But, considering the replacement cost for a 'real' '68 bezel, using one from another year makes sense to me. {Worrying about the whims of NCRS does not, IMO.}
In fact, I doubt that the deduction for having a '72 bezel would be any larger than having one from a '69...so, if it were me, I would leave it alone.
I too don't care about the whims of the NCRS (unless that stands for Not Correctly Restored Stringray ) I replaced my bezel with a 69 and it looks fine to me. Only I know it is the "wrong" one. No one around here would know the difference.
I have one that is broken at the narrow spot. Maybe I should put it in the for sale section.
Excellent information. Thank you for posting the link.
As for the pan assembly that the bezel is screwed to, that contains all of the gauges within it, and that the dash lights are mounted on the back of - was this different for the different years as well? E.g., if I buy a correct 68L bezel, will this assembly mount onto it correctly? Thanks again!
I believe that the 'pan' was the same for all years of C3's. Not positive of that, as the 'pan' is not sold as a replacement part, as far as I know. You can find them at swap meets occasionally. But, the plastic 'lens' for the gauges is identical for all years, so it's likely that the pan is also.
P.S. The way to investigate questions like this is to check out some of the aftermarket vendor's parts catalogs to see if parts apply to multiple years or not. (I like Corvette America catalogs, as they seem to contain almost all parts that are available.)
I think the 72 and up bezel is different. Other than the smooth finish that is 68 only, doesn't the 72 bezel not have the separation for the seatbelt button?? I could be wrong. I do know a 69, 70 (and 71?) will fit, it's just not the correct one as the finish is different. They do make a correct 68 reproduction. I have heard of folks buying a 69 bezel and sanding it smooth like a 68.
I think you meant July 68 built car and not 69? I see there's two answers from guys that just can't resist getting in a bash instead of answering a simple question- or just moving on.
If you're talking about NCRS Flight Judging, the score sheets are available for free download from the NCRS website:
The centre cluster as a whole is worth 6 points for originality and 5 for condition. The smooth vs. shiny is one aspect that differs, as does the physical configuration. Assuming what you've got is in good condition, you might get maybe a 2 point deduction at most for having a later service replacement piece.
Total points available for a car is 4510, so 2 points out of that is not worth even thinking of spending big bucks to get a correct '68 piece. For reference, a burnt out lamp would be a 25 point deduct. You'll notice also that the prediction way above of a 'significant deduct' is way way off.
If one of you have a correct 68, I would greatly appreciate it if you could post a picture of the instrument cluster so I get this right. Thank you again.
I dont know how much variation there was between early and late "pans" but here's mine, which I am pretty certain is original to the car. Its from a late October build though. The smooth cluster housing its mounted in is for a 68 but didnt come with the car. There's 2 sets of numbers above the radio *****, 69 on left, 68 on right. Overlook the wiring please, it was on the bench at the time, and I swapped out the oil gauge to electric. Hope it helps.
Don't worry to much about the part number on the back of your cluster. If you buy a repro 68 cluster, it will have the 72-76 part number cast in it also!
The repros are made buy taking the 72-76 cluster, grinding the grain off, adding the housing for the seat belt button, and then blocking the wiper override hole (if it's to be an early 68 cluster). Because of this, both the early and late 68 repro clusters, as well as 69-71 repro clusters, all have the 72-76 part number cast into the back of them.
The gauge pod should be interchangeable within all 68-76 center gauge clusters. 68-71 gauges will have digits with a green tint to them, while later ones are white, and the font style does change in later years. Also later oil gauges are electric, not mechanical.
John 65 - thank you for posting the picture, it is a big help. It looks like my only problem is in the upper right of the picture, which is where the seat belt warning push button is mounted. I don't have this on mine. What exactly is mounted on the bezel pan there? Is it a circuit board or something? Thanks!
Yes thats what it is, and the gray plastic peice in the center is a twist in light. It has nothing to actually do with the seat belts, meaning its not wired to them or anything. It just reminds you when the car is started.
Any suggestions on how to make that part of this correct? This assembly isn't available new. I have a call into a couple of corvette recyclers to see if I can get the correct parts that way. Or if the circuit is simple, perhaps it is something I can fabricate?
Tell ya the truth I went to a few websites and havent been able to find one also. Am sure you can find a used one on ebay or right here in the c3 parts forum. Do you have the rest of the it? Ya may just have to get hold of a beat up center cluster and take parts from it.
55Trucker: order the 68 assembly instruction manual (AIM). It will list the part number for the 68 bezel. I am not certain there is an early or late bezel; only the placement of the Tell Tales varied. IF there was an actual running change for the bezel, the AIM might show a drawing revision date.
Order the 68 NCRS Technical Information and Judging Guide. It will list an appproximate date and/or consecutive unit number for the change in Tell Tales.
Dr. Dobbins' book is a pretty good reference.
The 68 center bezel is smooth finished and one year only. Any other year will swap but will not be correct. If you have a 435hp car and are considering having it judged, why use anything other than a 68 cluster?
SHMOKY: Several of us around here would know your bezel is wrong.
There is an Early and Late bezel. The early ones have one (I think top right) warning light blocked off. Early 68 bezels also only have a 68 part number on the back. Late 68 (still smooth but no block off) have 68 and 69 part numbers.
As I mentioned earlier, bezels made for a 72? and Up are NOT the same. You could though get a 69 or 70 bezel for a cheaper price and sand it smooth.
Otherwise, REPRO early and late 68 only bezels are available.
Here's a couple pictures of the circuit board for you.
What is that cylindrical thing on your board? A relay or something?
And a stupid Forum-Novice question: how did you paste those pictures in your response? The Insert Picture button did not work for me when I said the picture URL was "c:\bezel.jpg"
