Heater controls
Old Jan 18, 2012 | 11:30 AM
Capt Ken's Avatar
Capt Ken
Default Heater controls
While I await the arrival of an owners manual can someone please describe how the heater controls work. As you roll the control ***** forward to back, some of the positions are self explainitory, others not. How is the level of heat adjusted....assuming by the position of the marker in the heat zone, is hot at the forward or back end of the scale.
73 t top with air conditioning
Old Jan 18, 2012 | 01:14 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
Left **** controls which ducts are used and right controls the temp. SB cold at the top and warm at the bottom. Also for the left ****, the settings toward the bottom have the AC compressor turned off so you don't get any dehumidifying.
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If memory serves, one end says COLD, the opposite end says HOT.
Regardless, try it. Fire it up. Let it get to operating temperature, and play with the thumbwheels.
Old Jan 18, 2012 | 03:34 PM
Capt Ken's Avatar
Capt Ken
Default Thanks
I did a cursory look and it didn't jump out at me....but then the car hasn't been cleaned in ages so maybe that will help.
Doing the cleaning part as I await gas tank parts...hopefully can check it out this weekend.
To Heater controls
