Need some help identifying this wire?
Old Jan 24, 2012 | 08:40 PM
wan2run's Avatar
wan2run
Originally Posted by daanbc
I just assumed since I was able to bend it, and it stayed in that position that there was metal wire in it. I took a closer look today, then tried to slice some of the covering away, only to realize it was hollow. Now I need to find where it connects to.
OK, I dug through the archive.
My car has cruise and it feeds into the "T" from the headlight switch vacuum line coming through the firewall and the vacuum to the cruise control transducer.
Follow the red trace
Let me know of you need the full res pics and I'll send them to your e-mail.
Old Jan 24, 2012 | 09:54 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Thank you very much, mine to has cruise. But it never worked. Maybe because of this. LOL. I will check tomorrow. Thanks again, at least im getting somewhere with this line...
Old Jan 24, 2012 | 10:31 PM
texasbaehr's Avatar
texasbaehr
I think Wilcox called it: it is identical to my 81, the solid black vacuum line goes to the water valve. Mine was cut and I had to splice it with a small section of rubber hose.
Its solid black. Where on the intake does it connect to? THANKS by the way......
