Engine seal kit location
Old Jan 24, 2012 | 05:34 PM
jdenn47's Avatar
jdenn47
Default Engine seal kit location
I bought an engine seal kit for my 76 vette from Ecklers, EC16H.
It came with several rubber seals. I found where some go but not others. Don't know where the 2 Fender skirt splash shield weatherstrips go. Or the Upper 7 lower fender seal kit, (6 pcs.) go. Or the Bumper brace seals go. Can anyone help for locations? JD
Old Jan 24, 2012 | 06:13 PM
Alan 71's Avatar
Alan 71
Hi JD,
I tried to find EC14H at Ecklers but couldn't; all their part numbers seem to be 4 or 5 digits.
So I'm not sure just what seals you're asking about.
I'm thinking maybe the seals for the top of the aprons to the hood surround, and perhaps the seals for splash pans at rear/bottom of the aprons.
Just a guess.
The second are easy to replace. The first can't be done unless serious front fiberglass work is being done.
Regards,
Alan
Old Jan 24, 2012 | 08:49 PM
Tom73's Avatar
Tom73
Originally Posted by Alan 71
Hi JD,
I did a google search for EC14H and came up with a seal kit from New York RestoMod http://www.newyorkrestomod.com/product_p/ec16h.HTM
Part Notes: (13 piece kit), Includes the following: Upper andlower fenderseal kits, A-Arm dust covers W/ fasteners, windhield wiper motor seal, fender skirt splash shield weatherstrips, steering column seal(s), fuse box gasket (63-67), battery cover access gasket (63-67 W/Air or 396), radiator support and fan shroud seals (66-67 where applicable), bumper brace seals (68-79) and front marker lamp seals (80-82)
Old Jan 25, 2012 | 05:38 PM
jdenn47's Avatar
jdenn47
Sorry, the part number from Eklers is 38664 and it is a 13 pc. kit that covers 76- 79.
Old Jan 26, 2012 | 11:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The assembly instruction manual (AIM) will show the originals.
Old Jan 26, 2012 | 05:08 PM
jdenn47's Avatar
jdenn47
The Kit from Eklers only show the listed items, no manual or diagrams.
Old Jan 27, 2012 | 10:07 AM
Easy Mike's Avatar
Easy Mike
Order the assembly instruction manual (AIM) and you will not have to rely upon instructions from your kit vendor. The AIM will show you all of the factory installed seals, weatherstripping, dust shields, etc.
Trust me: you are going to want the AIM for other projects too.
Old Jan 29, 2012 | 06:43 PM
jdenn47's Avatar
jdenn47
Thanks, I ordered the AIM from the NCRS.
To Engine seal kit location
