need info on search engine
Old Jan 25, 2012 | 11:26 AM
lonebull's Avatar
lonebull
Default need info on search engine
Using the search engine on this forun is there a way to keep the search just on c3's? I enter c3 but the search always covers all vettes. Any advice?
Old Jan 25, 2012 | 11:33 AM
fanmanbd's Avatar
fanmanbd
You need to go to the C3 category you want to search and use the red search this forum button not the top search button.
Old Jan 25, 2012 | 12:32 PM
lonebull's Avatar
lonebull
solved my problem completely! thank you very much. lonebull
Old Jan 25, 2012 | 04:12 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
another choice is to go to the advanced search and simply select the forum heading you wish to search. if you don't pick one it will search every forum. if you select a main heading, it will only seach the threads associated with that main heading. if you pick only on of the sub forums, that is the only place the search will take place.
To need info on search engine
