ID these gears please !!
Old Jan 27, 2012 | 03:19 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default ID these gears please !!
trying to confirm what gear this is.. sorry the pics arent the best,
Old Jan 27, 2012 | 03:38 PM
mysixtynine's Avatar
mysixtynine
I don't think anyone will be able to read those numbers. You would have to type them in by hand or take clearer pictures.
If all you care about is the ratio then just turn one of the stub axles one complete rotation and count how many times the pinion turns. If it turns 2 and 3/4 times its a 273 if it turns 3 1/2 times its a 355 and so on. (This only works on posi rears that are still together there is a different way for open rears but we dont care about that here.).
Old Jan 27, 2012 | 04:02 PM
ptroxx's Avatar
ptroxx
OKso these are the numbers I can read
3735*90 11:7 gm 8 70
and I think its going around about 3.4-5 times,....
Old Jan 27, 2012 | 04:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Use Photo Viewer and rotate them until you can read them.
Old Jan 27, 2012 | 04:13 PM
ptroxx's Avatar
ptroxx
I did that Mike, and the numbers sure look real close ....
Old Jan 27, 2012 | 04:41 PM
joewill's Avatar
joewill
i don't think you are going to find a ratio on the ring gear with those numbers, the numbers are stamped on the pinion gear.. in this example
the date is 12/74 and the ratio is 12/37 = 3.08
Old Jan 27, 2012 | 04:47 PM
scottyp99's Avatar
scottyp99
Just count the number of teeth on the ring, then count the teeth on the pinion, and divide the larger number by the smaller number. It's not rocket surgery.
Scott
Old Jan 28, 2012 | 06:34 PM
tracdogg2's Avatar
tracdogg2
11:37 3.36 gears
Old Jan 28, 2012 | 08:07 PM
ptroxx's Avatar
ptroxx
Originally Posted by tracdogg2
11:37 3.36 gears
To ID these gears please !!
