Matching Numbers
Old Jan 29, 2012 | 12:22 PM
Cobfree's Avatar
Cobfree
Default Matching Numbers
I know this question has been asked several times but just trying to confirm numbers.
VIN 194678S425827
engine stamp 18S425827
What does the 18S on the engine stamp stand for?
Would the sequence number refer that this is the 25,827 vette built by St. Louis?
Old Jan 29, 2012 | 12:33 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you only got the partial engine stamp. but you do have a numbers matching engine
Old Jan 29, 2012 | 12:34 PM
Cobfree's Avatar
Cobfree
Great thanks
Old Jan 29, 2012 | 12:48 PM
Cobfree's Avatar
Cobfree
Let me check
Old Jan 29, 2012 | 12:50 PM
BKarol's Avatar
BKarol
This will break down the vin for you:
http://corvetteactioncenter.com/specs/c3/1968/68id.html
The suffix on the pad will tell what engine is in there as opposed to what someone told you is in there.
Old Jan 29, 2012 | 12:52 PM
bkvette3's Avatar
bkvette3
Sorry Cobfree - my mistake - Mine shows a 18S also on the pad. Noontime here and I am still not thinking straight.
Old Jan 29, 2012 | 12:55 PM
Mike Ward's Avatar
Mike Ward
The 1 means that it's a Chevrolet product. The 8 is for 1968 model year. 25827 is the sequential build number so yes it's the 25,827 1968 Corvette built.
Although the numbers 'match' this does not guarantee that it's the original factory engine or stamp.
Old Jan 29, 2012 | 01:03 PM
Cobfree's Avatar
Cobfree
Just checked and HE is stamped on the engine for the 327/300hp manual that it is.
Thanks, can't wait for the weather to get better to get it out again.
Old Jan 30, 2012 | 09:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...What does the 18S on the engine stamp stand for?...
1 Chevrolet
8 1968
S St. Louis assembly plant.
...Would the sequence number refer that this is the 25,827 vette built by St. Louis?...
Yes. All 68s have the 4 following the S in the VIN. I'm guessing your car was built in July, 1968. The time/build code is in the upper right corner of the trim tag.
Old Jan 30, 2012 | 09:57 AM
Cobfree's Avatar
Cobfree
I will look tonight , thanks
To Matching Numbers
