Yep the car has a mechanical gauge and I'm putting an electric one in. Was mainly just checking if I split the voltage between both gauges: I wouldn't get a false reading.
Yes, you can just tap into a power line that feeds another gauge. It will not affect the readings.
{And, "accurate" is not the word I would apply to ANY GM factory gauge. The 'accuracy' of a GM mechanical gauge or a GM electrical gauge is about the same.}
all the above would be fine, but my choice would be to tap power off one of the unused switched locations on the fuse box. just a suggestion to go along with all the others.
Cause many people (falsely) believe that electric gauges are more accurate than mechanical?
It might be because the mechanical guage has a plastic tube that is attached to the guage. It is possible and has happened that after many decades the plastic tube lets go and spews hot oil at 40 psi all over the back of the dash and the carpet.
Some have replaced the plastic tube with a copper tube (available from many vendors). The safest way to go is the electric guage if you can find one that matches the font and color of the other guages.
That´s the reason for me changing the gauge .
Look at my thread :
When I bought my '73 I noticed a small oil leak where the plastic tube connects to the block next to the distributor. The ferrel had cut into the tube from being overtightened. Eventually it would have completely let go and spewed oil all over the engine compartment with the high probability of a fire.
So...if you use a copper tube or a new plastic tube, DO NOT overtighten the ferrel against the tube. Tighter is not better.
