Speedo-Tach Dash Panel Removal
Old Jan 31, 2012 | 02:28 PM
Stroh's Avatar
Stroh
Default Speedo-Tach Dash Panel Removal
I'm following Wilcox instructions on how to remove this piece, I've removed / disconnected everthing (steering column, light wiring, etc) they've detailed and it's still hung up on something. I'm taken it really slow and easy not wanting to break anything. Even consulted the AIM (AIM guy) and still stuck.
Anybody do this recently that can help me out?
Old Jan 31, 2012 | 02:54 PM
Sully1882's Avatar
Sully1882
push up on the top dash pad while with other hand pulling down and forward with the lower dash pad. The upper pad hangs down over the lower. If the steering column is out and you took the three screws out of the top of the lower pad along with the two screws in the door jamb area it should be loose and pull out at least enough to get behind and disconnect the light switch and the gauge stuff... good luck and go slow. You don't want to fracture that thing.
Sully
Old Jan 31, 2012 | 04:30 PM
jim-81's Avatar
jim-81
Also make sure you disconnect the speedo cable (push in the clip that holds it in), and unplug the main wiring harness, also unplug the tach cable from the console by the shifter console. I just did this last night (mine's an 81) and what a pain. It did not feel good when it finally came out, but it came out and does not appear to be damaged. I had to replace all the lights (15 of them, yikes).
To Speedo-Tach Dash Panel Removal
