Diff and Manual Trans oil
Old Feb 1, 2012 | 12:21 PM
briaineo's Avatar
briaineo
Default Diff and Manual Trans oil
Do anyone run the same gear oil in their diff and their manual trans?
If I use the pump/siphon out method of draining the trans through the fill hole how much can I hope to remove? M21 just checking to how much I need to purchase
thanks
Old Feb 1, 2012 | 12:27 PM
TWINRAY's Avatar
TWINRAY
In my '67 with the Muncie, I run GL4 in the gearbox. Rear axle lube is GL5 which I've read is really no good for gearboxes - has to do with it "eating up" the syncro's. GL4 is hard to obtain (for me anyway) locally. I bought a case a couple of years ago from a supplier in Pa. and had it shipped.
ps. with a siphon gun, I've never had much luck getting much out from the "add" hole - probably half a qt. If you can get it up on a lift, you would have better luck in getting more out.
Old Feb 1, 2012 | 12:50 PM
7T1vette's Avatar
7T1vette
You need to get the oil warmed up first, so it will thin-out, before you will have any luck with a siphon. As stated, the higher the car, the longer siphon tube you can use so that it will flow faster. Even then, it will take a while. When it gets down to the bottom of the 'punkin', you might do better with a turkey baster and hose.
Old Feb 1, 2012 | 01:25 PM
RMVette's Avatar
RMVette
When I changed my differential oil I used two bottles of GM rear axle lubricant and one bottle of GM Positraction additive.
I personally would not use the same oil in both the tranny and differential.
Old Feb 1, 2012 | 02:16 PM
fanmanbd's Avatar
fanmanbd
The newer GL5 gear oils are MT-1 rated so they are now a replacement for GL4 applications.
Old Feb 1, 2012 | 02:19 PM
Ironcross's Avatar
Ironcross
80-90W both places:.....
Old Feb 2, 2012 | 04:53 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
What he said. Look for the MT1 spec which is designed to protect the tranny's yellow parts.
I use Valvoline 80w-90 in both my Muncie and the differential.
Old Feb 6, 2012 | 05:55 AM
briaineo's Avatar
briaineo
thanks for all the advice
Which would you recommend: mineral or synthetic or semi?
Old Feb 6, 2012 | 07:41 AM
fanmanbd's Avatar
fanmanbd
I use synthetic motor oil and conventional gear lubes, but any combination will work. It's your preference.
Old Feb 6, 2012 | 08:52 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Been doing it that way for 40 years. Just add one 4 oz bottle of GM posi lube to the rear end
Old Feb 6, 2012 | 09:08 AM
Marlin's Avatar
Marlin
EDIT:
Mobil1 75w90 use to say MT1 but I don't see it at mobils site anymore. Advance and other sellers still say it meets MT1 spec.
MT1 though is for heavy duty LARGE trucks trans so it does not have to say MT1 to be safe but helps if I understand correct.
So Mobil1 75w90 MIGHT work in both the diff and manual trans.
To Diff and Manual Trans oil
