Do I have an L88?
Old Feb 1, 2012 | 05:51 PM
harlandbaker's Avatar
harlandbaker
3rd Gear
Default Do I have an L88?
I just acquired a 68 corvette that the owner says he was told it was an L88 that no longer had the original engine or hood. so, I am interested what I could look at to either rule out an L88 or confirm.
So here is what I know. it has no radio, no heater, no A/C, it has two leaf springs that go left to right in the back (sway bar?), it has a sway bar in the front. it has a 4 speed manual that when you shift into reverse is up to the right instead of down.
it has a hardtop convertible option
Is there anything I could look at that could confirm it's heritage besides the engine and hood which are missing?
Thanks for your input.
Old Feb 1, 2012 | 06:26 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
If the tranny is original it would have the vin & a date code & it would be an M-22 not an M-21 what is the vin # ? does it have a metal plate where the radio would have been ? what is the redline on the tach ? is there a red & white decal on the center console regarding fuel / octaine ? Have you checked on top of the gas tank for a tank sticker build sheet yet ?
Old Feb 1, 2012 | 06:29 PM
KO68's Avatar
KO68
There were only 80 L88s made in 1968. Drop the gas tank and see if the original tank sticker is on it. Without the tank sticker there would be no other way of telling exactly what motor was originally in the car. A 6500 red line tach was on the L88 and the 435 hp motor cars. Post some pics of the dash with radio and heater delete. Sounds interesting.
Old Feb 1, 2012 | 06:35 PM
harlandbaker
3rd Gear
the VIN is 194678s403986, the original console in the car has been replaced with what looks like maybe a 69 console, redline on tach is 5400 ish. I have part of the build sheet which shows it came with a big block, 4 speed, posi, however, most of the sheet is missing. color code is 02976AA MED/BLUE, tinted glass. it does say 390HP Turbo-J.... it is cut off from there. I am leaning towards it being just a plane old big block corvette, however, I thought I would check with the experts.
Old Feb 1, 2012 | 06:38 PM
427SIXPACK's Avatar
427SIXPACK
Agreed, but will help eliminate the other motors & narrow it down further !!!
Old Feb 1, 2012 | 06:45 PM
427SIXPACK's Avatar
427SIXPACK
That would be 5600 ( ish ) / and there is your answer....
If it is the original tach it would be for a 390 horse or 400 tripower car
NOT AN L-88
Old Feb 1, 2012 | 07:11 PM
harlandbaker
3rd Gear
Thanks everybody for your input.
Old Feb 1, 2012 | 07:34 PM
63Corvette's Avatar
63Corvette
What kind of BRAKES do you have??? Single pin, or double pin?
Old Feb 1, 2012 | 07:38 PM
Mike Ward's Avatar
Mike Ward
I now understand the full life cycle of old Corvettes. Any car missing it's engine 'was once' an L88, and any old engine pulled from a junkyard 'was once' from a Corvette. Cool!
Not picking on you OP. Be glad that you have SOME paperwork showing how it was born -most owners can just wish.
Old Feb 3, 2012 | 12:38 AM
TimAT's Avatar
TimAT
I am amazed at the numbers of Chevrolet cars and trucks for sale with "Corvette" engines. It's a wonder that GM had any left for Corvettes.
Old Feb 3, 2012 | 10:33 AM
7T1vette's Avatar
7T1vette
Someone trying to sell his product that 'embellishes' the story....
Imagine that....
Old Feb 5, 2012 | 10:51 PM
Mark_Milner's Avatar
Mark_Milner
Most here probably don't understand that, or the proportioning valve.
Of course, if they bothered to take the engine and hood, they probably took the brakes.
Old Feb 6, 2012 | 09:43 AM
Roughrider's Avatar
Roughrider
There's probably a lot more "genuine" L88 engined and other big block Corvettes running around now than Chevrolet ever assembled and sold. Add "genuine" Camaro and Chevelle big block cars out there today and it makes it appear that high option big block cars were the norm, not the exception when it came to production.
If Chevrolet were ever to find the production records of the era and made them available, there would be many, many owners crying "foul" when they discovered their "rare" Corvettes left the factory as anything but what they own.
Old Feb 6, 2012 | 12:11 PM
joewill's Avatar
joewill
even before your answers came back with so many replies stating it is not a L88, your chance of it being a real L88 car was pretty close to zero...
but a 68 big block convertible is a great basis anyway. does it have a BB in it, or is it a project?
Old Feb 6, 2012 | 06:43 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Muncie 4 speeds, with "normal" shifters, accessed reverse gear by pushing "left" through the neutral gate, in other words toward the driver, then "up" toward the dashboard.
Old Feb 7, 2012 | 03:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...it does say 390HP Turbo-J.... it is cut off from there...
That means it had an L-36 big block, but not an L-88.
Old Feb 7, 2012 | 09:06 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
NOT AN L-88
........also check the fuel lines if they appear to be "original". I believe all Q-Jet equipped cars(427/390hp & smallblocks)will have a smaller return line to the tank. The Holley equipped cars(400hp, 430hp & 435hp)will have only a single "supply" line running along the frame.
Old Feb 7, 2012 | 09:34 PM
PeteZO6's Avatar
PeteZO6
... leaning towards it being just a plane old big block corvette, however, I thought I would check with the experts.
Heh heh, just a plain old big block Corvette indeed. Count your blessings and enjoy your BBC Corvette
Pete
Old Feb 7, 2012 | 09:37 PM
The13Bats's Avatar
The13Bats
No my 69 was an ZL-1 car....
To Do I have an L88?
