Tie Rod Clamps
Old Feb 3, 2012 | 07:58 PM
POLICE COPTER's Avatar
POLICE COPTER
Default Tie Rod Clamps
I have a basic question about tie rod clamps. I am installing new tie rod ends and tubes but can't seem to get the clamps to fit. I can't get the clamp bolt though due to the tube being in the way.
The car is a 1971/350
Old Feb 3, 2012 | 11:22 PM
7T1vette's Avatar
7T1vette
Turn the clamp so that the split in the clamp and the split in the tube are lined up. Then, the bolt should go through.
Old Feb 4, 2012 | 09:13 AM
Jim Shea's Avatar
Jim Shea
In this paper I tried to explain the tie rod and adjuster tube positions and adjustments as called out in the AIM. It is a Microsoft Word .doc. The picture in this document may be a bit clearer than the one above.
http://jimshea.corvettefaq.com/?p=1021
If your adjuster tube has a groove on the OD on one end, that is the end that is outboard. Tubes are oriented that way on both sides. If your tubes do not have a groove, then the left hand thread should be positioned outboard on both sides. There is a sketch that goes along with the scan from the AIM that shows the adjuster tubes with the grooves.
BTW, contrary to 7T1vette's posting, the AIM specifically says the following:
"If necessary rotate a clamp a maximum of 45 degrees either direction so that the slit in the adjuster tube is not in line with the slot in the clamp."
I am sorry that I can't comment on your problem of getting the clamp bolt through the clamp. I can only comment on the AIM direction that says not to have clamp slots and tube slots aligned.
Hope that the paper helps.
Jim
Old Feb 4, 2012 | 11:07 AM
69 Chevy's Avatar
69 Chevy
You might consider doing away with those OEM adjusting sleeves and installing these solid tubes with jamb nuts. I have a like-new pair at half price, $25. PM me if interested.
Old Feb 4, 2012 | 11:25 AM
7T1vette's Avatar
7T1vette
Interesting. Wonder what the 'logic' for that would be?
To Tie Rod Clamps
