Grease locations
Old Feb 8, 2012 | 03:39 PM
mayor28's Avatar
mayor28
Default Grease locations
As part of my "Scheduled Winter Maintenance," I wanted to grease all of the important fittings on my vette. As I haven't ever done this, I was hoping you all may have some suggestions on tough to locate fittings, or uncommon locations.
Also, does someone have a good thread detailing the process to grease the U-Joints (or am I being a newb and this isself explanatory?)?
Thanks!
Old Feb 8, 2012 | 04:03 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check your u-joints. Stock did not have grease fittings. Most of the replacements do. Six of those.
Four ball joints; idler arm.
Check the steering box.
Old Feb 8, 2012 | 04:19 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
do you have a service manual. if not get one. the first couple of pages has all the maintenance info on them
Old Feb 8, 2012 | 04:51 PM
MelWff's Avatar
MelWff
***** joints(4), tie rods(4), idler arm, power steering valve, clutch cross shaft, drive shaft(if not OE), half shafts(if not OE).
Old Feb 8, 2012 | 06:10 PM
startwith80vette's Avatar
startwith80vette
and don't forget Rydell High
Old Feb 8, 2012 | 06:42 PM
billcarson's Avatar
billcarson
and under my fingernails.use extreme caution when greasing the power steering control valve.or don't do it at all.read up on it.it needs just the right amount of grease.(?)
To Grease locations
