74 power steering ???
Old Feb 8, 2012 | 08:24 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default 74 power steering ???
I replaced the pump and the cylinder. It still takes both arms to steer this car. I still have the original hoses installed. Could that possibly be the problem? I'll change them out either way but thought I'd ask. Thanks for any opinions.
Old Feb 8, 2012 | 09:01 PM
mrmagrath's Avatar
mrmagrath
Did you recondition the power valve?
Old Feb 8, 2012 | 09:32 PM
fotyfobravo
Brand new. Only thing not replaced was the hoses.
Old Feb 8, 2012 | 09:35 PM
mrmagrath's Avatar
mrmagrath
With mine, I put the valve in the pump in back to front with the same symptoms as you have. Take the high pressure hose off the pump and pull the assembly to see if it's in right!
Old Feb 8, 2012 | 10:08 PM
fotyfobravo
Thanks! I will check the valve when I replace the hoses.
Old Feb 9, 2012 | 12:34 AM
grahambb's Avatar
grahambb
the valve might be worth rebuilding while you are in there, if it is leaky.
BG
To 74 power steering ???
