79 4spd back up light
Old Feb 8, 2012 | 08:45 PM
C3 4ME's Avatar
C3 4ME
Default 79 4spd back up light
Can anyone confirm what the shape if the rod that goes from the switch to the reverse bracket is? In my AIM and service manual, it shows the rod as being straight. I have picked one up from Zip and it is bent on one end at about a 15 degree angle. I've been trying for several years to get my back up lights working correctly, and this is the 2nd or 3rd rod I've gotten from Zip and all were bent exactly the same. There was no switch or related components on my car when i bought it, so I have no point of reference. KapsSA, how about your 79, or anyone else with an untouched 79 4 spd?
Old Feb 9, 2012 | 08:23 AM
John 65's Avatar
John 65
Hope it helps.
Old Feb 9, 2012 | 09:04 AM
gbvette62's Avatar
gbvette62
Originally Posted by John 65
That looks like the right rod to me. AIM and Shop Manual illustrations, often vary slightly in appearance, from actual parts. These illustrations aren't meant to be used to identify parts, but instead to indicate there installation. Even the factory parts book's illustrations, often vary in appearance, from the actual parts.
All 75-81 4 speed Corvettes used the same rod, switch and bracket.
Which trans and shifter, do you have? The original trans was a Borg-Warner Super T-10, though some 78-79's had Saginaw's. Either way, they both used the same switch, etc. Muncie's and early T-10's, used a completely different bracket, switch and rod. Aftermarket shifters (Hurst, etc.), are usually designed to work with stock back-up lamp switches, but I can't say that this is always the case.
If the switch and rod were missing, who knows what else may have been changed by a previous owner.
Old Feb 9, 2012 | 09:37 AM
BKarol's Avatar
BKarol
If you look in Dr. Rebuild's catalog he says the 75-81 switch rod has been discontinued. Substitute 68-73 rod- heat & bend as required.
If you go to Ecklers site, it looks like they sell a straight one:http://www.ecklerscorvette.com/corve...1975-1981.html
Also, according to Ecklers the bent one appears to be for a Muncie.
Old Feb 9, 2012 | 02:49 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I'll TRY to get a look at mine, but it might be hard!
Barn is jamb packed with winter storage cars
I'll go through my pictures, too.
Old Feb 9, 2012 | 07:12 PM
KapsSA's Avatar
KapsSA
Couldn't get my big head under there so I stuck the camera in and got this................
Old Feb 9, 2012 | 07:54 PM
C3 4ME's Avatar
C3 4ME
Ok, I didn't think to mention, I do have a Hurst shifter, but I assumed the bracket that the reverse rod attaches to was original. I do have the original BW ST10 trans. John65, the rod I bought was exactly like your picture. KapsSA, yours looks dead straight to me. yours is the most original 79 I know of, and I really appreciate you taking the time to get that picture for me. I think that the reverse bracket on the side of my trans is exactly the same as yours, by your picture. Does anyone think the Hurst shifter would make any difference?
Old Feb 10, 2012 | 12:15 AM
KapsSA's Avatar
KapsSA
Here's another pic that better shows the connection to the linkage.....
Old Feb 11, 2012 | 07:53 AM
C3 4ME's Avatar
C3 4ME
Thank you again KapsSA. The reverse rod bracket you show is definitely the same as what's on my car. I won't be able to get back on it 'till next week, as the car is at an indoor car show all weekend.
Old Feb 11, 2012 | 01:40 PM
GD70's Avatar
GD70
Here's another few pics. The rod had the bend when I installed the switch. You can sort of see it in the first pic. The Vette had a hurst shifter also.
Glenn
To 79 4spd back up light
