T-Top Question
Old Feb 10, 2012 | 11:44 PM
TO_Vette's Avatar
TO_Vette
Default T-Top Question
On my 1981, the T-Top it locks in two places, in the front and the back. The front one clamps on in a scissor fashion just on the top of the windshield.
In the back, there is a pin that gets pushed into a hole in the back via a long shaft that is attached to the lever.
On the passenger side, this pin is not attached to the shaft so when I lock the lever the pin never gets pushed into the hole.
I can see that the pin is threaded so I’m assuming that it should screw into this shaft. Am I correct?
Also, is there a trick to get this pin screwed on the shaft, tried for like
30 mins with no luck?
Old Feb 11, 2012 | 12:00 AM
Procrastination Racing's Avatar
Pictures? It is been too long since I had one of those tops to help you but maybe the rod is broken or stripped.
Pictures would let us see what you are talking about.
Old Feb 11, 2012 | 10:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by TO_Vette
...Am I correct?...
Yes.
The problem is the bullets can break off the threaded section of the latch rod. Ask me how I know.
Old Feb 11, 2012 | 10:38 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Going to be hard to fix this without pulling rod out. I honestly don't remember for sure but I think you can pull the rod out and replace it. My guess is like Mike's, the tip broke off and the threads are messed up on the end from it.
To T-Top Question
