Rear Diff. Help
Old Feb 12, 2012 | 02:32 PM
D&D Engine Works's Avatar
D&D Engine Works
Cruising
Default Rear Diff. Help
I bought a rear differential over the weekend and need some help decoding the stampings on the bottom. The guy said it was for a 68 model. 3899143 D 14 8 OK 150 W85 and maybe a 7 after the W85. Hard to read. Also were is the cheapest place for rebuild parts. I will be selling this differental if someone is interested. thanks derrick 606 306 3300
Old Feb 13, 2012 | 11:50 AM
MelWff's Avatar
MelWff
here is a link to all codes
http://corvettec3.ca/axle.htm
Old Feb 14, 2012 | 09:32 AM
george2066's Avatar
george2066
Default search the forum
you going to find this done many times, pics and instuctions, I worked with gtr1999, turned out great!
Old Feb 14, 2012 | 10:17 AM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
WOW great link..... thanks....
Old Feb 14, 2012 | 11:40 AM
flyeri's Avatar
flyeri
Two quick questions for you concerning the info on the link. I have a 3.70 and want to go to a 3.08. What is the difference in an AT and an AW, if any? When I look at ring and pinion sets from Corvette venders as well as Summit I see no mention of heavy duty. Are the ring and pinion the same on either (AV vs. AT and AW) or does the heavy duty refer to case and other components? Thanks
Old Feb 14, 2012 | 11:53 AM
tracdogg2's Avatar
tracdogg2
3.08 and 3.70 use the same 3 series carrier. HD means nothing.
Mike
Old Feb 14, 2012 | 12:33 PM
Yellow74c3's Avatar
Yellow74c3
Are the codes on the rear center section?
Old Feb 14, 2012 | 02:19 PM
tracdogg2's Avatar
tracdogg2
I'm having a little trouble understanding the original post. You bought a diff. You don't know what year it is? (it's a 78, not 68). You are looking for a place to buy the cheapest parts. You are planning on rebuilding it and sell it to someone here on the forum?
Mike
Old Feb 14, 2012 | 02:21 PM
tracdogg2's Avatar
tracdogg2
Yes, on the bottom rail just in front of the rear cover. The codes tell you what it was originally was, not what it is now.
Mike
Old Feb 15, 2012 | 04:00 AM
ptroxx's Avatar
ptroxx
Mike
WIsh we were closer you could have my 308 ill take your 370.. LOL
I just ordered a new trans from bowtie OD 2004r and want the 370's.....
Im just going to get a set from Toms I think and pull the rear myself...
Old Feb 15, 2012 | 11:12 AM
Yellow74c3's Avatar
Yellow74c3
Mike
Got it, Thanks, Fred
To Rear Diff. Help
