81 AC Vent
You probably pulled a vacuum line loose in the engine compartment when you were changing the plugs. Vacuum operates the deflector doors in the HVAC system. With no vacuum going to the control head, the system probably defaults to "Heater" mode.
Thank you for your knowledge and input,will check tose vacuum lines out for leak or pulled off.because a/c vents worked prior to plug wire install,bouvie1
