L82 Motor ?
Old Feb 12, 2012 | 06:55 PM
Zelda's Avatar
Zelda
5th Gear
Default L82 Motor ?
Does anyone no the 9 numbers on the front of the block are thay part
of the VIN # I no the 8 numbers are plant day year and motor ??
1975
Old Feb 12, 2012 | 10:17 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Yes, the 9 digit sequence on the left end of the engine pad is the VIN. It should obviously match your title, plus the VIN located on the drivers side winshield pillar.
Old Feb 13, 2012 | 08:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There are two stampings on the pad. The first is the engine stamp which will tell you when the engine was assembled and identify the engine (L-48 or L-82). ZBA or ZBB are the L-82 codes for '79.
Second stamp is the VIN derivitive.
To L82 Motor ?
