headlights from different year???
Old Feb 15, 2012 | 12:26 AM
hdoggie24's Avatar
hdoggie24
Default headlights from different year???
Does anybody know what years for headlights are compatible with eachother? I have a 72 vette (new guy to the forum), was able to get a set from a 75 for nothing and was wondering if any or all of it would be compatible? thanks for the info if you can help
Old Feb 15, 2012 | 01:13 AM
tracdogg2's Avatar
tracdogg2
75-82
Only the horseshoe bracket is different. Everything else is the same.
Mike
Old Feb 15, 2012 | 01:15 AM
hdoggie24's Avatar
hdoggie24
thanks.....so if i just get that bracket i should be good to go to use everything else??? thanks, appreciate it
Old Feb 15, 2012 | 08:51 AM
Sully1882's Avatar
Sully1882
here's what I have found:
68 unique
69-72 same
73-74 same but diff from 69-72 b/c the change with molded front bumper, will work in earlier model car but must have a small spacer between front nose bar and front tabs of horse shoe bracket.
75 & up much shorter extensions on the horse shoe and won't work on earlier models
HTH,
Sully
Old Feb 15, 2012 | 08:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by hdoggie24
Does anybody know what years for headlights are compatible with eachother? I have a 72 vette (new guy to the forum), was able to get a set from a 75 for nothing and was wondering if any or all of it would be compatible?...
Yes. Your 75 lights will mount in your 72 with 1/2" spacers on the two front mounts (nose bar) of each support.
Old Feb 15, 2012 | 11:26 AM
hdoggie24's Avatar
hdoggie24
thanks. that is good news. glad i can use what i have. anybody know a site where they did this? would like to see some pics if possible
Old Feb 15, 2012 | 12:43 PM
Easy Mike's Avatar
Easy Mike
...would like to see some pics if possible...
Do you have the 72 assembly instruction manual (AIM)? The AIM has several diagrams of how the headlight assemblies were installed. Your 75 units will mount the same way as shown in the AIM with the exception of the spacers.
To headlights from different year???
