1971 clock knob removal
Old Feb 16, 2012 | 09:39 PM
2001convertable's Avatar
2001convertable
Default 1971 clock **** removal
Hi, does anyone know how to remove the clock stem ****. Iam removing the gauge bezel and not sure how to remove the **** off the clock....thanks
Old Feb 16, 2012 | 09:52 PM
spdrcr29's Avatar
spdrcr29
Mine is all boxed up and packed away awaiting restoration completion. However if I remember correctly, doesn't the **** unscrew? Isn't there a very small sloted screw holding the **** in place??
Old Feb 16, 2012 | 09:56 PM
C6DuffMan's Avatar
C6DuffMan
There's a tiny screw in the center of the ****. Mine is a flat (slot) head. Need a small, small screwdriver. Like a jewelers one.
Old Feb 16, 2012 | 10:00 PM
2001convertable
I will look in the morning. You say theres a phillips holding it? Ill tell you that I worked on this interior for so many hours tonight that I think Iam loosing it. Sometimes you have to just walk away untill the next day. Thanks so much.
Old Feb 16, 2012 | 10:02 PM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
My 72 has a flat head screw holding it in.
Old Feb 16, 2012 | 10:05 PM
Alan 71's Avatar
Alan 71
Hi 2001,
There's also a tiny 'sleeve' that slips on the time setting rod to fill the gap between the **** and the gauge bezel. Be careful you don't lose it.
I agree... slotted screw.
Regards,
Alan
Old Feb 17, 2012 | 10:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Alan 71
...Be careful you don't lose it...
Truth be told, you can be careful and still lose it. Been there, done that.
To 1971 clock knob removal
