Pricing Help on 73 convert project
Old Feb 22, 2012 | 08:25 PM
MichaelP's Avatar
MichaelP
Default Pricing Help on 73 convert project
I need help determining a fair value for this project that I need to sell. I started it and cannot finish it at this time.
I have a 73 Convertable that had the nose off (accident) and I did a fairly extensive restoration on everything from the fire wall forward.
Frame is straight and checked by local specialist.
Here's what I have into it:
MECH:
350/350 HP crate motor. I still have original L-48.
Headers
rebuilt Corvette distributor w/ tach drive
rebuilt TH400 and new converter
suspension bushings
ball joints
wheel bearings
calipers & rotars (all)
front brake lines
steering cylinder
master cylinder
exhaust pipes and mufflers
air conditioner compressor
AC VIR
AC evaporator
AC hoses
fan shroud
chome alternator
chrome power steering pump
new gas tank and straps
heater core
BODY:
Sanded an primed entire car with 2-part primer.
rebuilt drivers door (all metal, no rust at strike)
refinished dash with Med. Saddle finish
Installed salvaged front clip
new headlights, housings, springs & vac diaphrams for lights
new chrom exhaust tips and trim
FRAME:
Sandblasted and repainted frame from fire wall forward, frame extension, rad support & radiator.
Welded hole in drivers side rale in front of rear tire
new endcap on drivers side
pass side front frame horn was straightened
Rear has not been touched and is showing signs of age
NEEDS:
Seats
carpet
radio
new convert rag top, have good frame/cage
back bumpers re-chromed, has good cores
front emblem
door handles rechromed
drivers mirror (glass only)
front vac system installed
Door threasholds redone or replaced
seat belts
body block sanded and painted
rims and tires
I have most every thing else neede to put it back together.
Mike
Old Feb 23, 2012 | 05:13 PM
GPGG70's Avatar
GPGG70
Sorry I can help you with your what it's worth question, but I have to say it's to bad you have to sell your project and and nice one at that. With a little more time involved it would be finished. Good luck.
Old Feb 23, 2012 | 11:45 PM
Clubby99's Avatar
Clubby99
Nice project for someone.
I might pay $8,000 if local and I wanted to start another project.
Old Feb 25, 2012 | 07:39 PM
MichaelP's Avatar
MichaelP
Thanks for info guys.
It has been extremely painful to even seriously consider selling the car.
To Pricing Help on 73 convert project
