View Poll Results: Do you like the car?
Very Much
11.11%
Yes
29.63%
Indifferent
11.11%
No
24.07%
Definitely Not
24.07%
Multiple Choice Poll. Voters: 54. You may not vote on this poll
Paint and Stripes! What Do You Think??
Old Feb 23, 2012 | 11:54 PM
CorvetteFirstTimer's Avatar
CorvetteFirstTimer
Default Paint and Stripes! What Do You Think??
In about a year, I am looking to start on painting my 1979 Corvette. I want a nice show paint, but it also needs to be sporty. Please give all your ideas and thoughts.
Right now its maroon and its a beautiful color, so I'm having a hard time accepting other colors. So, SHOW ME YOUR PAINT!
I also have another issue. I like the stripes but I am a little OCD. I know the engine is off center by a few inches, which makes the supercharger off center, which makes the hole in the hood off center. If I wanted to do two stripes again, one would have to be wider than the other like it currently is, or I could make them the same width centered on the car and it will look weird compared to the hole in the hood. I wanted to keep the stripes, so what are your oppinions: Keep them, change the dimentions on them, different graphic, one stripe, ect....the input is appreciated.
Old Feb 24, 2012 | 07:17 AM
Tim H's Avatar
Tim H
Why is one stripe wider than the other?
Get rid of the stripes and since your car isn't close to being stock don''t paint it a stock color.
Old Feb 24, 2012 | 07:28 AM
WICKEDFRC's Avatar
WICKEDFRC
Maybe he missed the whole point you made reference the stripes.
That is a bit weird how the engine is off center, making everything else off center, but perhaps making one stripe wider and one narrower compensates for that off-center mismatch and cleans it up.
Honestly, I think the maroon looks awesome, but the white stripes are not working for me. Maybe if they better matched the chrome wheels?
Or maybe black wheels, black stripes?
Or just remove the center stripes and go with a rally type stripe down one side with a smaller rail stripe?
Old Feb 24, 2012 | 07:35 AM
929nitro's Avatar
929nitro
I would remove the stripes if it was mine.
Old Feb 24, 2012 | 07:58 AM
454LS6's Avatar
454LS6
Whats wrong having a stock color on an non-stock car? Whether its stock or not makes absolutely no difference as long as it looks good in the eyes of the beholder.. That is my opinion on stock colors.
OT: Electric Blue with white stripes would look good. As well as having gray as base and stripes on black, hard to imagine but looks amazing, that is what i am going for in the future.
Old Feb 24, 2012 | 08:09 AM
Mark Riles's Avatar
Mark Riles
I have always liked the Baldwin Motion stripes. I do not like the ones you currently have though I like the color and how the wheels and side pipes work with everything. I think a set of white BM striped would look good and since the entire L88 bulge would get the treatment your OCD wouldn't interfere as much with your interpretation of it.
Old Feb 24, 2012 | 08:12 AM
The Money Pit's Avatar
The Money Pit
I like the maroon color. The white stripes seem a bit too much for me, but if I were to offer a suggestion,...How about an accenting maroon stripe, either a shade or two lighter than the body color, and styled like the old Chevelle SS cowl stripe.
Old Feb 24, 2012 | 08:18 AM
lvrpool32's Avatar
lvrpool32
I would make the hole bigger so it is equal on both sides. For a stripe I would a do centered single RS stripe (say 8" wide with a 1/4" pinstripe either side) and run it all the way through the nose...or an RS stripe that starts wider in the back of the hood and comes thinner towards the front (to match the hood line)
So basically what you are left with is just the engine bieng over to one side, which will (if everything else is parrallel) only be noticeable if you are looking dead on from the front (and most people probably will not notice). If you leave the off center hole and the unmatched stripes, you are just emphasising the issue.
Other options...get a fiberglass scoop that dzus fastens to the hood...this can be placed in the middle and hide the offset issue.
Do some form of ghost stripes , so they arent as obvious and will not exaggerate the engine placement.
Old Feb 24, 2012 | 09:23 AM
RobRace10's Avatar
RobRace10
The stripes don't look right, the two different sizes seem weird and in my opinion they should continue through the bumper no matter what stripes you have.
Old Feb 24, 2012 | 10:03 AM
Mashman's Avatar
Mashman
I agree with many of the preious posts.
My take is that it currently looks kind of wierd.
In my opinion, I think it would look better with:
1) A single stripe
2) Stripe should be centered on car
3) Stripe should be wider than supercharger
4) Stripe should continue thru the bumper
5) Stripe should not be white - too much contrast, I think a darker color such as black, or a very dark blue would work much better.
The above is just my opinion, but my biggest recommendation is for you to do something that makes you smile and say to yourself - 'Damn...I can't believe that's MY car!', every time you look at it!
Old Feb 24, 2012 | 10:29 AM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Yeah, what he said...
ALL C3 engines are offset to the passenger side - a fact some Corvette owners don't even know.
Love the Maroon - Keep it. Add a metallic black single stripe about 14" wide starting right at the motor or a little before. Do a blunt pointed tip. Maybe add a C3 decal at the front of the stripe. Put small silver accent stripes on either side of the center stripe starting at a point, or coming off the C3 decal and increse width to about 2".
Old Feb 24, 2012 | 10:57 AM
69 Chevy's Avatar
69 Chevy
Then it matches the rest of the car.
Old Feb 24, 2012 | 11:14 AM
toddalin's Avatar
toddalin
I'd do one fat stripe, with a pin stripe on each side, wide enough to encompass the entire top of the "bulge" section of the hood. Then the offset would not be visible and no longer an issue.
Old Feb 24, 2012 | 11:24 AM
7T1vette's Avatar
7T1vette
One wide stripe that will encompass the entire opening in the hood. Small pin stripes outside that, if you want. Also, you need to run the stripe all the way around the front bumper. Cutting it off at the bumper looks a bit odd, IMO.
Old Feb 24, 2012 | 11:43 AM
HeavyMetalHawk's Avatar
HeavyMetalHawk
This and the yellow combo of the zl1 are the only stripes that I like
Old Feb 24, 2012 | 11:52 AM
Mark Riles's Avatar
Mark Riles
That's gorgeous.
Old Feb 24, 2012 | 12:07 PM
Scott MacDonald's Avatar
Scott MacDonald
I'm a graphic designer, I've just been to the Toronto Auto Show and paid a lot of attention to the new vettes. The theme these days is to accent with Carbon Fibre. I would look at a matt finish stipe, probably black. but only stripe the raised cowl area and only the top of the raised portion, not down the raised sides and keep the distance between the stripes to no more than 1 inch wide. If you use a Carbon Fibre vinyl, do the same treatment as I just mentioned. You only need to do the hood. Don't carry on to the roof or the rear deck. If you are looking for a brighter stripe, go for a silver but not charcoal, too dark against the burgundy. For a killer look, paint the car matt black with gloss black stripes.
To Paint and Stripes! What Do You Think??
Old Feb 24, 2012 | 12:11 PM
CorvetteFirstTimer
For anyone wondering...I didn't paint the car like this. I bought it like this. The reason one stripe is wider than the other is because if you notice, the cut out for the pulley is off center to the actual hole in the hood that is off center. He made them two different sizes because he didn't want white paint to be just on one side of the hole and not show up on the other. I don't plan on making the hole bigger centered on the hood. I think that would looke even worse, plus, whoever cut the hood before did a really nice job. I like the suggestions. I always liked the stripes, but I think I would do one solid strip. Maybe a ghosted stripe for what ever paint I choose. What are your thoughts on a light metal flake? I saw a 2012 camaro with a charcoal color with a flake in it and it was gorgeous
Old Feb 24, 2012 | 12:15 PM
CorvetteFirstTimer
Oh, and to be honest, I don't think the stripes are paint. It has a little edge to it and at first I thought the stripes were added after and just not cleared with the rest of the car, but I think the previous owner went the cheap way and used vinyl. I think that may be why he didn't allow the strip to go to the side of the hole on the right, because it would be in a pain in the neck. My goal is to make the car better than the way I bought it.
Old Feb 24, 2012 | 12:17 PM
CorvetteFirstTimer
I love those stripes, I just don't know if it would look right on my car, meaning it has the large rear window, where this car actually has some room to paint on the back
