Tri Power Question
Old Feb 27, 2012 | 10:59 AM
avenger88's Avatar
avenger88
Default Tri Power Question
I have a 1967 rectangular port tri power set up that I wanna put on a 69 vette. Is the 67 tri power manifold a higher rise design than the 68-69 manifold? Most importantly if it is higher will it fit under a 69 BB hood?
Old Feb 27, 2012 | 11:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do the Google Thing with the part number of the 67 manifold. It could be the same as the 68-69 manifold.
Old Feb 27, 2012 | 11:33 AM
7T1vette's Avatar
7T1vette
Can't you just measure it?
Old Feb 27, 2012 | 01:12 PM
69MA's Avatar
69MA
The 67 manifold will not fit under a 69 hood. Too tall.
Old Feb 27, 2012 | 01:46 PM
avenger88's Avatar
avenger88
[QUOTE=7T1vette;1580126088]Can't you just measure it? [/QUO
Figured it would be easier to ask and get an answer from some one who knows these cars rather than trying to measure from the block deck or bottom of existing manifold to under side of closed hood. Dont you think? So do you know if they are the same hight or if the 67 is taller???
Old Feb 27, 2012 | 02:38 PM
1Fordman's Avatar
1Fordman
The 67 is approximately 1-1/2" taller than the 68-69 tri power intakes. Will fit under an L-88 style hood.
I would like to find a 67 tri power rectangular intake and sell the 68 intake. Have an L-88 hood on the car so clearance is not an issue.
Old Feb 27, 2012 | 03:54 PM
avenger88's Avatar
avenger88
thanks for the info! I would like to sell my 67 rectangular port tri power & carb set up and get a 68 set up. .if you have any interest shoot me a pm
Old Feb 27, 2012 | 09:23 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Old Feb 27, 2012 | 10:40 PM
1Fordman's Avatar
1Fordman
I just want a bare manifold as my carbs are all fresh, new fuel lines and linkage and re-chromed air cleaner lid. Thanks for the offer. I would think a complete 67 setup would sell easily.
Old Feb 27, 2012 | 10:46 PM
avenger88's Avatar
avenger88
My carbs are the same as 68 carbs so they should bolt right up?
Old Feb 28, 2012 | 10:09 AM
1Fordman's Avatar
1Fordman
They will bolt to a 68/69 manifold. The only difference is the 67 primary carb has the lever operated bowl vent and the 68/69 does not.
To Tri Power Question
